Hello, we at Team 3128 are having a very strange problem. Over Ethernet and USB, we can connect to our robot fine. But, when we connect over wi-fi, the driver station (and SmartDashboard and web dashboard) do not connect to the robot unless the laptop has just been rebooted. If I connect without rebooting and ping roborio-3128-frc.local, it does not find the host. It kind of smells like some kind of mDNS problem, but I have no clue what it could be. The driver station is a Lenovo Thinkpad T430, and these problems started summer 2016, around the time that the driver station upgraded itself to Windows 10.
At that point, we figured out that connecting an ethernet cable to the robot, connecting wifi, and then disconnecting the ethernet allowed us to connect normally. I figured that the problem was the Windows 10 upgrade, so I clean installed Windows 8 on the computer and put in a new SSD. That made it reboot faster, but the connection problems didn’t go away. Then, when I upgraded the driver station to the 2017 update suite, the Ethernet workaround stopped working.
I also tend to see the error “The mDNS service is slow to respond. Check firewall settings” in the driver station. I turned off the Windows firewall, and it did not solve the connection issues.
I also tried restarting certain NI network services, turning wifi on and off, installing Apple Bonjour (because it also supports mDNS) and disabling every network interface but wifi. None of these helped. I can only connect to the robot if it is the first network that the laptop connects to after booting up (though strangely, I can connect to another network, disconnect as quickly as possible, then connect to the robot, and it does work).
This error happens across at least three different robots (all of the ones we’ve tested), and occurs with the 2016 and 2017 wireless bridge. I didn’t test the older D-Link one.
Could there be something interfering with NI’s mDNS service? What could be causing this error? Why would it persist across Windows reinstalls? Could it be some kind of network driver update that got pushed last summer?
NOTE: I also posed this on the NI forums here, and got no response.
