Hello, so I am trying to set up a Raspberry Pi 3 model B to use as a vision coprocessor this season. I installed Raspbian and followed the steps here to set up the vision project for a Lifecam 3000 plugged into the Pi via USB. I am able to successfully run the code generated by GRIP and send the values to networktables; however, I haven’t been able to get the camera stream to work. The example code from the WPILib vision library supposedly enables this. It creates a CVSource and feeds that into MjpegServer, which, from what I’ve read, should enable you to drop frames into the CVSource and have them sent to the SmartDashboard. At first I thought it might be that the server port was blocked, but I tried using a different radio without the FMS firewall enabled and it still won’t work. Is there a step I’m missing in code? or is there something I have to configure on the Pi to enable it to host a stream?
The only reason I really need the stream is for tuning the GRIP project, so if there was a way to view the output of the script on a monitor connected to the Pi, that would work too.
Here’s the code that’s running on the Pi:
import java.util.ArrayList;
import edu.wpi.first.wpilibj.networktables.*;
import edu.wpi.first.wpilibj.tables.*;
import edu.wpi.cscore.*;
import org.opencv.core.Mat;
import org.opencv.imgproc.Imgproc;
import org.opencv.core.*;
import org.opencv.core.Core.*;
import org.opencv.features2d.FeatureDetector;
import org.opencv.imgcodecs.Imgcodecs;
import org.opencv.imgproc.*;
import org.opencv.objdetect.*;
public class Main {
public static void main(String] args) {
// Loads our OpenCV library. This MUST be included
System.loadLibrary("opencv_java310");
// Connect NetworkTables, and get access to the publishing table
NetworkTable.setClientMode();
// Set your team number here
NetworkTable.setTeam(5102);
NetworkTable.initialize();
// This is the network port you want to stream the raw received image to
// By rules, this has to be between 1180 and 1190, so 1185 is a good choice
int streamPort = 1185;
// This stores our reference to our mjpeg server for streaming the input image
MjpegServer inputStream = new MjpegServer("MJPEG Server", streamPort);
// Selecting a Camera
// Uncomment one of the 2 following camera options
// The top one receives a stream from another device, and performs operations based on that
// On windows, this one must be used since USB is not supported
// The bottom one opens a USB camera, and performs operations on that, along with streaming
// the input image so other devices can see it.
// HTTP Camera
// This is our camera name from the robot. this can be set in your robot code with the following command
// CameraServer.getInstance().startAutomaticCapture("YourCameraNameHere");
// "USB Camera 0" is the default if no string is specified
String cameraName = "USB Camera 0";
HttpCamera camera = setHttpCamera(cameraName, inputStream);
// It is possible for the camera to be null. If it is, that means no camera could
// be found using NetworkTables to connect to. Create an HttpCamera by giving a specified stream
// Note if this happens, no restream will be created
if (camera == null) {
camera = new HttpCamera("CoprocessorCamera", "YourURLHere");
inputStream.setSource(camera);
// USB Camera
// This gets the image from a USB camera
// Usually this will be on device 0, but there are other overloads
// that can be used
UsbCamera camera = setUsbCamera(0, inputStream);
// Set the resolution for our camera, since this is over USB
camera.setResolution(640,480);
camera.setExposureManual(0);
GripPipeline pipeline = new GripPipeline();
// This creates a CvSink for us to use. This grabs images from our selected camera,
// and will allow us to use those images in opencv
CvSink imageSink = new CvSink("CV Image Grabber");
imageSink.setSource(camera);
// This creates a CvSource to use. This will take in a Mat image that has had OpenCV operations
// operations
CvSource imageSource = new CvSource("CV Image Source", VideoMode.PixelFormat.kMJPEG, 640, 480, 30);
MjpegServer cvStream = new MjpegServer("CV Image Stream", 1186);
cvStream.setSource(imageSource);
// All Mats and Lists should be stored outside the loop to avoid allocations
// as they are expensive to create
Mat inputImage = new Mat();
Mat hsv = new Mat();
NetworkTable targets = NetworkTable.getTable("GRIP/targets");
// Infinitely process image
while (true) {
// Grab a frame. If it has a frame time of 0, there was an error.
// Just skip and continue
long frameTime = imageSink.grabFrame(inputImage);
if (frameTime == 0) continue;
// Below is where you would do your OpenCV operations on the provided image
// The sample below just changes color source to HSV
Imgproc.cvtColor(inputImage, hsv, Imgproc.COLOR_BGR2HSV);
// Here is where you would write a processed image that you want to restreams
// This will most likely be a marked up image of what the camera sees
// For now, we are just going to stream the HSV image
pipeline.process(inputImage);
String point = pipeline.findContoursOutput().toString();
targets.putString("test", point);
imageSource.putFrame(inputImage);
private static HttpCamera setHttpCamera(String cameraName, MjpegServer server) {
// Start by grabbing the camera from NetworkTables
NetworkTable publishingTable = NetworkTable.getTable("CameraPublisher");
// Wait for robot to connect. Allow this to be attempted indefinitely
while (true) {
try {
if (publishingTable.getSubTables().size() > 0) {
break;
Thread.sleep(500);
} catch (Exception e) {
// TODO Auto-generated catch block
e.printStackTrace();
HttpCamera camera = null;
if (!publishingTable.containsSubTable(cameraName)) {
return null;
ITable cameraTable = publishingTable.getSubTable(cameraName);
String] urls = cameraTable.getStringArray("streams", null);
if (urls == null) {
return null;
ArrayList<String> fixedUrls = new ArrayList<String>();
for (String url : urls) {
if (url.startsWith("mjpg")) {
fixedUrls.add(url.split(":", 2)[1]);
camera = new HttpCamera("CoprocessorCamera", fixedUrls.toArray(new String[0]));
server.setSource(camera);
return camera;
private static UsbCamera setUsbCamera(int cameraId, MjpegServer server) {
// that can be used
UsbCamera camera = new UsbCamera("CoprocessorCamera", cameraId);
return camera;
