Hello evereyone!
My team is having trouble running PID position closed-loop control on our drivetrain with TalonSRX to get to a certain position. We tried breaking the code into smaller and smaller pieces and ended up in opening a new blank robot project with only the required lines for the pid written. (as attached)
When we run the PID, our robot just drives forward without stopping. we printed both the current position of the talon and the setpoint it had received to the SmartDashboard and could clearly see that it just skips by the target and keeps moving forward.
Please advise. Is anything in our way of using PID on TalonSRX wrong? Is there something else going on?
Thanks a lot in advance, Aric.
P.S. We also tried running the code that’s located in the teleopPeriodicin teleopInit (meaning it only ran once and not periodically) and results were the same.
package org.usfirst.frc.team3339.robot;
import com.ctre.CANTalon;
import com.ctre.CANTalon.FeedbackDevice;
import com.ctre.CANTalon.TalonControlMode;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public static OI oi;
private CANTalon rearLeft = new CANTalon(3);
private CANTalon rearRight = new CANTalon(1);
private CANTalon frontLeft = new CANTalon(2);
private CANTalon frontRight = new CANTalon(0);
@Override
public void robotInit() {
oi = new OI();
frontRight.reverseOutput(true);
rearRight.reverseOutput(true);
frontLeft.setFeedbackDevice(FeedbackDevice.QuadEncoder);
frontLeft.reverseSensor(true);
frontLeft.configEncoderCodesPerRev(360);
frontLeft.setPID(0.2,0,35,0.5115,0,0,0);
frontLeft.configMaxOutputVoltage(12);
@Override
public void disabledInit() {
@Override
public void disabledPeriodic() {
Scheduler.getInstance().run();
@Override
@Override
@Override
public void teleopInit() {
frontLeft.setPosition(0);
@Override
frontRight.changeControlMode(CANTalon.TalonControlMode.Follower);
frontRight.set(2);
rearRight.changeControlMode(CANTalon.TalonControlMode.Follower);
rearRight.set(2);
rearLeft.changeControlMode(CANTalon.TalonControlMode.Follower);
rearLeft.set(2);
frontLeft.changeControlMode(TalonControlMode.Position);
SmartDashboard.putNumber("Setpoint", frontLeft.getSetpoint());
SmartDashboard.putNumber("Position", frontLeft.getPosition());
frontLeft.set(5);
@Override
public void testPeriodic() {
LiveWindow.run();
