I know that 2471 has the theoretical ability for a sub second climb. They use a PTO from a 6 cim drive for that. My team has a subsecond climb on paper but in reality it takes about 1.25 seconds.
Long drum (6 - 8in), hook side velcro riveted to drum, drum driven by a 100:1 VersaPlanetary on a 775pro. Support the drum on the other end with a pillow block. Use a “fuzzy” 3/8in rope with a LOOSE slipknot in it (to generate slack for the rope to become fully engaged with the drum before the weight of the robot is on it.).
Also, make sure you have “pokey bits” to trigger the sensor, as the drum will hit the bottom of the Davit channel first.
EDIT: Drum shouldn’t be larger than 1.75 in in diameter
EDIT 2: the naming scheme for Versa planetary is stupid, it should be named 1:100
If you’re having specific issues with your design, you can make a new thread to ask for help. This thread is talking about the sub-second climbs teams are achieving in competition. You can PM me if you have any other questions.
Yup. That said their climb was average due to the way that they acquired the rope. They claimed that theyou could theoretical impart 4000lbs of force on the rope.
If you are inquiring about our bot in particular… we are at somewhere near 110 lbs. We do not qualify for sub second climb, although it is relatively qiuck. Our climber does have a fair bir of bang though (we had to throttle it back to something we were more comfortable with using).
I accounted for that in my definition, “sub second climb club” was just too good of a click-baity title.
Both conventions are used interchangeably throughout all of the FRC product world. It’s certainly confusing, but considering how rare it is in FRC to over-gear a motor, it’s usually pretty clear what is meant.
