Subsystem cannot be null
I am sorry for the lack of resources, but I am not with my robot at present, and thus cannot provide the full stack trace. But basically, I am both command programming my robot and using CAN-based jaguars. So, in my subsystem constructors, I have to add the line “throws CANTimeoutException” because that is where I naturally initialize my jaguars. However, when I compile and deploy my Java code, right before the line in the console that says “GOT_CONNECTION_FROM_CLIENT”, I see a stack-trace that says “Subsystem must not be null”. Again, I apologize that I don’t have the stack trace message, but it basically finds the error in the line of code that says that that the required(whateverSubsystem) line is throwing the exception. I have a strong suspicion that the two are linked. When I commented out this line, I got a CANTimeoutException after the “GOT_CONNECTION_FROM_CLIENT” line when I clicked “Enable” in the driver station app. Naturally, because the subsystem constructors throw the error, so does the init() method of the CommandBase.
Has anyone experienced this? Should I replace all of my “throws” statements with internal try/catch blocks? Other options? I’ll try post the stack trace errors during my Advisory period at school when I can access the robot next, which would be no later than 10:15 AM PST, but it maybe as late as 2:15 PM if that is not possible.
Thank you all.
Is your OI initiAlized before your subsystems?
Yes. Does that the commands initialize before the oi is set? That would make sense.
Then one of your buttons’ commands is probably require()ing a subsystem that hasn’t been initialized yet, and is thus null. I’d recommend leaving OI as the last to be initialized.
Yeah, I just realized that. Wow, I can be an idiot sometimes.
