Successful I2C connection to PixyCam in C++?
We used the pixycam last year… quite happily connecting to the digital/analog X interface format. It was so easy! :slight_smile:
This year we were planning to use the I2C interface to the pixy to gather more data on the targets it sees. Unfortunately we are having no success in talking to the pixy using the I2C class in the WPILib (C++). :mad:
We created an I2C object as follows:
// note: 0x54 is the default address for the pixy (verified using PixyMon)
// ... and we have also tried the kOnBoard port option too
I2C *pixyI2C = new I2C(frc::I2C::kMXP, 0x54);
We have tried all of the following operations and all are returning true indicating an abort of the command (ie. fail):
uint8_t testvalues[2];
uint8_t pixyvalues[64];
pixyI2C->ReadOnly(64, pixyvalues);
pixyI2C->Read(0, 64, pixyvalues);
pixyI2C->Transaction(testvalues, 2, pixyvalues, 64);
pixyI2C->AddressOnly();
We have tried different size reads and different transactions. The AddressOnly() is supposed to tell you if it sees the device… apparently it does not. :confused:
We have also tried hooking up an oscilloscope to the SDA and SCL pins which both remain high all the time indicating that it is not receiving any signal. It does not even appear to send the start sequence to the I2C port. Although we have documentation about the packets pixy will send with the target details, unfortunately we don’t have any documentation that provides any details of the commands that are required to be sent in order to get pixy to reply.
We would like to know if anyone has gotten the I2C interface work using the C++ version of the WPILib… especially interfacing to the PixyCam. On the other hand, any suggestions would be appreciated.
We have the pixy streaming information. I’m not thrilled with some intermittent artifacts, but it works well enough.
If SDA and SCL are high, that sounds like an initialization or wiring problem.
Here are some relevant code snippets. I stole the code from RoboDox-599 whom I believe stole it from the Arduino Library.
Short version:
#define PIXY_I2C_DEFAULT_ADDR           0x54
   I2C* i2c; //Declare i2c
      i2c = new I2C(I2C::Port::kOnboard, PIXY_I2C_DEFAULT_ADDR); //(I2C::Port::kOnboard or kMXP, Pixy Address)
uint16_t numBlocks = getBlocks(100);   //Retrieve up to 100 objects, record the num of objects found in "numBlocks"
      //The following code sprays data to the Driver Station for debug purposes only
      printf("blocks: ");
      printf("%d", numBlocks);printf("
"); //prints number of block to the console
      blocks[0].print(); // prints x, y, width, and etc. to the console (the vairables in the block object)
      printf("
"); //new line(space)
getBlocks() is defined below, We didn’t write it. It uses I2C.ReadOnly() to retrieve data from the Pixy.
Long Version:
#include "WPILib.h"
//Default address of Pixy Camera. You can change the address of the Pixy in Pixymon under setting-> Interface
// Communication/misc parameters
#define PIXY_INITIAL_ARRAYSIZE      30
#define PIXY_MAXIMUM_ARRAYSIZE      130
#define PIXY_START_WORD             0xaa55 //for regular color recognition
#define PIXY_START_WORD_CC          0xaa56 //for color code - angle rotation recognition
#define PIXY_START_WORDX            0x55aa //regular color another way around
#define PIXY_MAX_SIGNATURE          7
#define PIXY_DEFAULT_ARGVAL         0xffff
// Pixy x-y position values
#define PIXY_MIN_X                  0L   //x: 0~319 pixels, y:0~199 pixels. (0,0) starts at bottom left
#define PIXY_MAX_X                  319L
#define PIXY_MIN_Y                  0L
#define PIXY_MAX_Y                  199L
// RC-servo values - not needed unless you want to use servo to face the goal instead of moving the whole robot
#define PIXY_RCS_MIN_POS            0L
#define PIXY_RCS_MAX_POS            1000L
#define PIXY_RCS_CENTER_POS         ((PIXY_RCS_MAX_POS-PIXY_RCS_MIN_POS)/2)
enum BlockType
   NORMAL_BLOCK, //normal color recognition
   CC_BLOCK     //color-code(chnage in angle) recognition
struct Block
  // print block structure!
  void print()
    int i, j;
    char buf[128], sig[6], d;
   bool flag;
    if (signature>PIXY_MAX_SIGNATURE) // color code! (CC)
      // convert signature number to an octal string
      for (i=12, j=0, flag=false; i>=0; i-=3) //assigns value to signature, x, y, width, height, and anlge
        d = (signature>>i)&0x07;
        if (d>0 && !flag)
          flag = true;
        if (flag)
          sig[j++] = d + '0';
      sig[j] = '\0';
      printf("CC block! sig: %s (%d decimal) x: %d y: %d width: %d height: %d angle %d
", sig, signature, x, y, width, height, angle);
   else // regular block.  Note, angle is always zero, so no need to print
      printf("sig: %d x: %d y: %d width: %d height: %d
", signature, x, y, width, height); //prints out data to console instead of smartDashboard -> check on the side of the driver station, check +print and click view console
    //Serial.print(buf);
  uint16_t signature; //Identification number for your object - you could set it in the pixymon
  uint16_t x; //0 - 320
  uint16_t y; //0 - 200
  uint16_t width;
  uint16_t height;
  uint16_t angle;
class Robot: public IterativeRobot
private:
   Servo*servo; //not necessary unless you need servo. I used this for testing purpose
   SmartDashboard * dash; // not necessary
   BlockType blockType;// it is the enum on the top
   bool  skipStart;   //skips to check 0xaa55, which is byte that tells pixy it is start of new frame
   uint16_t blockCount; //How many signatured objects are there?
   uint16_t blockArraySize; //not used in the code
   Block blocks[100]; //array that stores blockCount array
   void RobotInit()
      servo = new Servo(9); //not necessary
   void AutonomousInit()
   void AutonomousPeriodic()
   void TeleopInit()
   bool getStart() //checks whether if it is start of the normal frame, CC frame, or the data is out of sync
        uint16_t w, lastw;
        lastw = 0xffff;
        while(true)
          w = getWord(); //This it the function right underneath
          if (w==0 && lastw==0)
            //delayMicroseconds(10);
           return false;
          else if (w==PIXY_START_WORD && lastw==PIXY_START_WORD)
            blockType = NORMAL_BLOCK;
            return true;
          else if (w==PIXY_START_WORD_CC && lastw==PIXY_START_WORD)
            blockType = CC_BLOCK;
            return true;
         else if (w==PIXY_START_WORDX) //when byte recieved was 0x55aa instead of otherway around, the code syncs the byte
           printf("Pixy: reorder");
           getByte(); // resync
         lastw = w;
   uint16_t getWord() //Getting two Bytes from Pixy (The full information)
      unsigned char buffer[2] = {0, 0};
      i2c->ReadOnly(2, buffer);
      return (buffer[1] << 8) | buffer[0]; //shift buffer[1] by 8 bits and add( | is bitwise or) buffer[0] to it
   uint8_t getByte()//gets a byte
      unsigned char buffer[1] = {0};
      i2c->ReadOnly(1, buffer);
      return buffer[0];
   uint16_t getBlocks(uint16_t maxBlocks)
     blocks[0] = {0}; //resets the array - clears out data from previous reading
     uint8_t i;
     uint16_t w, checksum, sum;
     Block *block;
     if (!skipStart) //when computer has not seen 0xaa55 (starting frame)
       if (getStart()==false)
         return 0;
     else
      skipStart = false;
     for(blockCount=0; blockCount<maxBlocks && blockCount<PIXY_MAXIMUM_ARRAYSIZE;)
       checksum = getWord();
       if (checksum==PIXY_START_WORD) // we've reached the beginning of the next frame - checking for 0xaa55
         skipStart = true; //starts this function
        //Serial.println("skip");
         return blockCount;
      else if (checksum==PIXY_START_WORD_CC) //we've reacehd the beginning of the next frame - checking for 0xaa56
        skipStart = true;
        return blockCount;
       else if (checksum==0)
         return blockCount;
      //if (blockCount>blockArraySize)
         //resize();
      block = blocks + blockCount;
       for (i=0, sum=0; i<sizeof(Block)/sizeof(uint16_t); i++)
        if (blockType==NORMAL_BLOCK && i>=5) // skip --if not an CC block, no need to consider angle
         block->angle = 0;
         break;
         w = getWord();
         sum += w; //sum = w + sum
         *((uint16_t *)block + i) = w; //converts block to interger value
       if (checksum==sum)
         blockCount++;
       else
         printf("Pixy: cs error");
      w = getWord(); //when this is start of the frame
      if (w==PIXY_START_WORD)
      else if (w==PIXY_START_WORD_CC)
      else
         return blockCount;
   void followBlock() //change servo into drive code, and it should work well :)
      if(blocks->signature == 1) //if pixy identify object 1
         if(blocks->x > 160) //if the object is on the right of the pixy (160 is about the middle)
            servo->Set(180); // servo goes to the left -- this may vary depending on the servo
         else if(blocks->x < 320 || blocks->x > 160) //if the pixy is on the left of the pixy
            servo->Set(0); //servo goes to the right
   int increment_since_last_find = 0;
   void TeleopPeriodic()
      int lastX;
      int lastY;
      printf("blocks: ");
      printf("
      // Code here checks numBlocks and updates last known x and y
      increment_since_last_find++;
      if(numBlocks > 0){
         lastX = blocks[0].x;
         lastY = blocks[0].y;
         //Show on Smart Dashboard
         SmartDashboard::PutNumber("Block @ X = ",lastX);
         SmartDashboard::PutNumber("Block @ Y = ",lastY);
      //Display how old our data is
      SmartDashboard::PutNumber("Inc since last update",increment_since_last_find);
      //This doesn't work! ergh...
      SmartDashboard::PutBoolean("Check Address Result",i2c->AddressOnly());
   void TestPeriodic()
START_ROBOT_CLASS(Robot)
David,
We can’t thank you enough for your quick and comprehensive response to our plea for information. Using your code as an initial test we were able to validate our setup and now have the pixy communicating successfully. :smiley:
In addition, the other thread you started here:
https://www.chiefdelphi.com/forums/showthread.php?t=154364&highlight=i2c+pixy
which provides moreinformation about the operational functionality of the I2C class was critical to our understanding why it appeared that nothing we had tried would work. After our first test, we had tried to keep our tests simple… which meant that we had been relying mostly on the functions that you note do not work at all. :yikes:
Good luck this season!
