Is there a way, when you reply to a message, to have it pop up any messages posted between when you loaded the page and when you clicked to post? I figure doing so would eliminate a lot of duplicate replies.
As long as you’re not using the Quick Reply at the bottom, once you hit ‘reply’ a list of replies will show at the very bottom of the page.
That helps if it takes you 5 minutes to read the post before replying, but doesn’t help if it takes you 5 minutes to write your post.
Are the posts on the bottom updated when you preview your post?
They are updated if/when you preview, I believe.
