Swerve Drive Specialties Lib Issues
So, my team has happened upon some issues with the SDS libraries for swerve module control. One thing is that you can not access the instances of the TalonFX motors or the CANCoder encoder, you can only get the steering angle, the dirve velocity, and set voltage and steer angle. That’s fine, except for the fact that something with the way they instantiate the motors or the way the control the motors once instantiated periodically causes a module to “drag” behind the others. It will be all fine and then all the sudden we will enable the bot and one of them is off, and we have to go through and either wait, just wait, literally, or redeploy code, or turn off the robot and turn it back on… listen, its so inconsistent and we’ve check our code and we know other teams are having the same issues.
Our team needs a java library for swerve drive to create modules. We are trying to develop our own, but with all the configurations that go into the motors for smooth motion, it’s a bit overwhelming. If anyone has a library they’d be willing to let us use with our current dual Falcon500 and CANCoder setup, I’d be more than greatful. I have been looking and I dont want to go to just a one off library, I am more looking to see if there is another supported library that many teams use.
I’m not familiar with using SDS, but you might find this thread useful:
In particular, see the advice to use WPILIB swerve support instead.
Mr. Matthews, thank you. We are using WPILIB for kinematics and odometry, those are great libraries.
UPDATE:
So… here’s the deal. After checking through source code from swerve-lib, we found some interesting functionality that is not apparent or discussed in their documentation, other than directly looking at their source code.
When creating a SwerveModule object from their library, they use a factory to create a configuration and then apply the configuration and instantiate the TalonFXs (or Neos) and the CANCoders. They control the position of the steering motor using the internal encoder on the falcon and seeding the position using the CANCoder. Their math is correct and nothing is wrong there so what could be the issue? It sporatically would drag a motor and then we would have it enabled, let it sit for ~10 seconds and it would “fix” itself… weird. So here’s the code that is both causing the issue and fixing the issue.
This is inside the setReferenceAngle() method for the Falon500SteerControllerFactoryBuilder
// Reset the NEO's encoder periodically when the module is not rotating.
// Sometimes (~5% of the time) when we initialize, the absolute encoder isn't fully set up, and we don't
// end up getting a good reading. If we reset periodically this won't matter anymore.
if (motor.getSelectedSensorVelocity() * motorEncoderVelocityCoefficient < ENCODER_RESET_MAX_ANGULAR_VELOCITY) {
    if (++resetIteration >= ENCODER_RESET_ITERATIONS) {
        resetIteration = 0;
        double absoluteAngle = absoluteEncoder.getAbsoluteAngle();
        motor.setSelectedSensorPosition(absoluteAngle / motorEncoderPositionCoefficient);
        currentAngleRadians = absoluteAngle;
} else {
    resetIteration = 0;
At first glance, you can tell they just copied over the code from the Neos Factory Builder and didn’t bother to change it, but to give them credit, it’s the same… for the most part. They explain that because of the initialization process they use, when the robot initially runs the code, it may not have properly seeded the position of the TalonFX using the CANCoder. So, their fix is when you call the set() method with your voltage and your desired rotation angle, it will then call this function down the setReferenceAngle() function, which if your robot is still, it will again seed the position.
Well, if you’re like our team and you do not usually have to tell your motors to go to zero in your disabledPeriodic() function in Robot, then you will not call this enough before you enable and you chance dragging a swerve module or two until you stop and wait 10 seconds (500 iterations if you look at the source code). Very frustrating.
TLDR: call your drive funcion with no velocity during your disabled periodic so i calls the setReferenceAngle function enough before you enable so that your modules have the correctly seeded angle.
Take a look at the suggested fixes for this Official SDS MK3 & MK4 Code - #99 by Zach_O
I wish I had seen that earlier smh. Your explanation and solution is much better laid out than mine here lol.
Replying so this doesn’t close :slight_smile:
