This could happen if not all the angle motors spin in alignment. You might need to invert one or two.
Put it up on blocks, and steer to a 45 degree angle, and see if all the wheels point the same direction.
Also double check that all the motor’s deviceNumber values are correct and unique.
BaseMotorController.setInverted can switch the response of motors, including the angle motors.
We looked into that earlier, but that doesn’t appear to be the issue. Without optimization, the robot drives as expected (with the robot flipping the wheels around rather than just driving the wheels backwards).
That’s why I suggested causing the wheels to rotate to 45 degrees on blocks, so you can verify the wheel angles visually, and isolate if all wheels are orienting themselves consistently.
Doing a 180 degree drive direction change will hide an angle motor that is in inverse settings, because X + 180 = X - 180
Doing a 90 degree path is also confusing, as the wheels are all pointing sideways, but one just spins the opposite way.
