This is our second year doing swerve I copied the code over from last year which worked but when I use the right stick to rotate the robot the wheels turn to the wrong angles
Desired:
Actual:
Here is my current code if anyone knows what I did wrong help would be appreciated.
public void driveWithJoystick(Joystick _joy) {
angle = ahrs.getYaw(); // defining variable for gyro
radians = angle * Math.PI / 180;
currentAngle = maxFLswerveEncoder.getPosition() / angleConstant; // setting the current angle of the wheel 11.4666
// = tick per rotation/360
currentAngle2 = maxFRswerveEncoder.getPosition() / angleConstant;
currentAngle3 = maxBLswerveEncoder.getPosition() / angleConstant;
currentAngle4 = maxBRswerveEncoder.getPosition() / angleConstant;
// swerve formulas
FWD = -(_joy.getRawAxis(1) /*+ _bakcupJoy.getRawAxis(1)*/);
STR = _joy.getRawAxis(0) /*+ _bakcupJoy.getRawAxis(0)*/;
RCW = _joy.getRawAxis(2)/* + _bakcupJoy.getRawAxis(2)*/;
if (FWD < .08 && FWD > -.08) {
FWD = 0;
if (STR < .08 && STR > -.08) {
STR = 0;
if (RCW < .08 && RCW > -.08) {
RCW = 0;
temp = FWD * Math.cos(radians) + STR * Math.sin(radians);
STR = -FWD * Math.sin(radians) + STR * Math.cos(radians);
FWD = temp;
R = Math.sqrt((Constants.L * Constants.L) + (Constants.W * Constants.W));
A = STR - RCW * (Constants.L / R);
B = STR + RCW * (Constants.L / R);
C = FWD - RCW * (Constants.W / R);
D = FWD + RCW * (Constants.W / R);
ws1 = Math.sqrt((B * B) + (C * C));
ws2 = Math.sqrt((B * B) + (D * D));
ws3 = Math.sqrt((A * A) + (D * D));
ws4 = Math.sqrt((A * A) + (C * C));
wa1 = Math.atan2(B, C) * 180 / Math.PI;
wa2 = Math.atan2(B, D) * 180 / Math.PI;
wa3 = Math.atan2(A, D) * 180 / Math.PI;
wa4 = Math.atan2(A, C) * 180 / Math.PI;
max = ws1;
if (ws2 > max) {
max = ws2;
if (ws3 > max) {
max = ws3;
if (ws4 > max) {
max = ws4;
if (max > 1) {
ws1 /= max;
ws2 /= max;
ws3 /= max;
ws4 /= max;
// swerve formulas
rotationAmmount = Math.IEEEremainder(wa1 - currentAngle, 360); // calculating ammount to move wheel
rotationAmmount2 = Math.IEEEremainder(wa2 - currentAngle2, 360); // calculating ammount to move wheel
rotationAmmount3 = Math.IEEEremainder(wa3 - currentAngle3, 360); // calculating ammount to move wheel
rotationAmmount4 = Math.IEEEremainder(wa4 - currentAngle4, 360); // calculating ammount to move wheel
if (FWD < .1 && FWD > -.1 && STR < .1 && STR > -.1 && RCW < .1 && RCW > -.1) { // not letting the wheels move unitll
// the joystick is pushed %10 down
fxFLdrive.set(0);
fxFRdrive.set(0);
fxBLdrive.set(0);
fxBRdrive.set(0);
} else {
fxFLdrive.set(-ws1); // driving drive wheel off the formulas
fxFRdrive.set(ws2);
fxBLdrive.set(ws3);
fxBRdrive.set(-ws4);
SmartDashboard.putNumber("wa1", wa1);
SmartDashboard.putNumber("wa2", wa2);
SmartDashboard.putNumber("wa3", wa3);
SmartDashboard.putNumber("wa4", wa4);
maxFLswervePID.setReference((currentAngle + rotationAmmount) * angleConstant, ControlType.kPosition); // moving the
// wheel
// to the
// required position
maxFRswervePID.setReference((currentAngle2 + rotationAmmount2) * angleConstant, ControlType.kPosition); // moving
// the
// wheel
// to the
maxBLswervePID.setReference((currentAngle3 + rotationAmmount3) * angleConstant, ControlType.kPosition); // moving the
// wheel
// to the
maxBRswervePID.setReference((currentAngle4 + rotationAmmount4) * angleConstant, ControlType.kPosition); // moving the
// wheel
// to the
