Yes, the Closes are handled with a Refnum Get straight to a Close.
There are some already in Finish.vi to guide you.
The fundamental difference between Autonomous Independent.vi and Teleop.vi is that Auto gets called only once, so you want to stay in there until you’ve done all you want to, while Tekeop gets called ~50 times a second, so you’ll be back again and again.
In teleop if you leave everything, but just remove the While loop it’ll be fine.
thanks! Ill try it on Monday (we don’t meet on Sundays unfortunately) and will post my failure or success here.
