Hi all,
I’m looking to switch our MK4i modules from L3 to L1 and could use some help figuring out the necessary parts.
Has anyone here done this before and can share a parts list or any tips?
Thanks in advance!
You only need to switch two gears (I’ve highlighted them below).
You’ll need this 19t gear and this 25t-50t double gear
As for changing them out, it’s not difficult at all. Just make sure to clean the bolts you remove and re-apply locktite. We had that 19t gear literally fall out during semi-finals last year…
The image didn’t work. Here it is:
