Sync Two Jags
How can I get two jaguars to sync together their PIDs when I only have one encoder. Should I have it that the one jag w/ encoder sens their voltage ramp to the jag without an encoder. How are other teams doing it?
The following thread has some ideas, but no resolution. http://www.chiefdelphi.com/forums/showthread.php?t=89282 When you get it working, be sure to let people know how you did it.
You can try using one in %Vbus, Vcomp, or Current mode, feeding it the value you’ve gotten from the controlling Jaguar.
For any of these options, you’ll want to do some processing to the data to get something acceptable. The trouble is, for low speeds the Jaguars like to return lots of zeros. (though perhaps my PID is tuned a little too high) When you tell a Jaguar in %Vbus or Vcomp to go “0”, it doesn’t ramp down, it just stops. This leads to very jerky movement. Perhaps a running average of the last 5 samples would work, or perhaps you just want to ignore all the zeros.
In Current Mode, the main issue is simply lack of accuracy. It’s ±2 Amps below 8A, and ±1A above. That means you better have a pretty big load in order to use it. However, large loads are usually where the double motor is necessary.
I’m planning on wiring the encoder to both motors, and having the PID independent. Because both Jaguars are subject to the same conditions, I’m hoping I won’t get significant integral windup. (Also, the integral is reset when the Jaguar output is “0”)
Is it possible to wire one encoder to two jags?
Yes, but you have to make a splitter for it.
Make sure to not wire the two 3v power supplies together, but connecting just their - terminal should be fine.
The way I was planning on doing it was taking a prototype board (5x3) and vertical 0.1" headers, and soldering across. That way, I could just take the encoder in its current configuration, plug it into the board, and have two adapter cables, one for each Jaguar.
It’s also possible to have a board that plugs directly into one of the Jaguars, but that’s a little harder to make.
ok I could just use an old PWM splitter cable
Not exactly. Quadrature encoders have more than three connections.
yea our’s has four connections but I can type them both to a common ground and 5v supply. The A&B channels will be split to the jags
We split the encoder like this.
A to both.
B to both.
GND to both.
VSupply from only one.
Don’t connect the supplies together unless you diode OR them and if you do that use germanium diodes for the low voltage drop across the junction.
We had a little discussion amongst ourselves about how this shouldn’t work, but given we’ve driven the Victor 884s unmatched into CIM gear boxes with a mere gear dividing the 2 output shafts, and given there’s reverse protection on both the Jaguars and Victors (in case something turns into a generator) the risks are low.
There is a chance that one Jaguar might drive more of the mechanism load than the other, as they are able to spin each other’s armature like this. It shouldn’t be too much of a problem and when the load on the mechanism increases they should both start to contribute. This will make tuning them interesting considering that effectively they are both in a state of semi-permanent runaway.
Only thing I will warn you about…we did this for a velocity set point…not position (haven’t thought about it the other way) and I strongly advise you to have a single harness handy in case someone thinks the split harness is causing your issues.
Hook up your encoder to you “master” Jags only. Put your “slave” Jags into absolute Voltage mode.
In your TeleOp Continuous loop, do:
slaveJag.setX(masterJag.getVoltage());
Mr. Lim, have you tried this?
I had little success in LabVIEW.
We have tried this, and anecdotally we are having success, in that we are able to get our robot to drive at the desired speeds, with what APPEAR to be balanced output from both. I haven’t scoped, or otherwise recorded, or graphed the values, and our slave Jags appear to run in virtual lock-step with the master Jags.
We are using Java, and I’m wondering if there could be a difference in the implementation between languages, or the fact that we’re passing the output voltage (i.e. -12V to 12V) from the master Jaguars to the slaves, and those output voltage values might be filtered to provide a meaningful value (i.e. not an instantaneous %Vbus).
Warning: I haven’t tested this or tried to model it, but it should work in theory… Of course, the devil is in the details.
Try wrapping a control loop around the two control loops on the Jaguars to sync their voltages up. The pseudo code would be something like the following, and you can make it more complicated if the nieve implementation doesn’t work. This is assuming that you are sampling the voltages of the two jaguars at the same time, and I’m not sure how much a difference in sample time between the two jaguars would effect things. Probably depends on how aggressive you are trying to sync the two.
v1 = jag1.getVoltage()
v2 = jag2.getVoltage()
error = (v1 - v2)
jag1.setX(goal - error * Kp)
jag2.setX(goal + error * Kp)
The basic idea is that you wrap a proportional loop around the two PID loops running on the jaguars in order to drive the voltage error between the two loops to 0. This should cause them to provide the same voltage to the two motors, and share the load nicely. It might also work if you try to drive the errors in the current that the two motors are drawing to 0, or something clever like that.
That’s an interesting method of doing it. It would probably be best to get the %Output status, not the Vout status, because the voltage would have to be scaled down anyway.
Then again, I don’t know what your “getVoltage” function does. Has it been modified to get the actual voltage, or does it return %Output?
I think it would make sense to monitor it first and see if any problems arise.
My “getVoltage” function returns some indicator of how much voltage the Jaguar is trying to put out. It is probably easiest to get the % Output from the Jaguar (should be -1, 1]) and use that, but theoretically, any indicator should work. The time constant should probably be pretty slow since you don’t care too much if they aren’t perfectly the same and just want the two to be pretty close.
If you connect the two GND wires together you can expect to have ground loop issues. This is only a problem with heavy loads where the motors are drawing significant current. We saw this issue last year in the CAN bus ground wire. We have an opto isolator in the circuit to prevent the ground loop.
So far the motors drive well. We see some unbalance, but not very much. We are still investigating if this unbalance is real, or inherit in our logging scheme.
Attached are two step response graphs from recent testing, one showing current and the other showing speed, both from the same run.
-Hugh
RA11_PIDtest_Practice_Match5_log_Current.pdf (71.9 KB)
RA11_PIDtest_Practice_Match5_log_Speed.pdf (72.5 KB)
Interesting. We’ll keep that in mind.
Thanks.
I didn’t see any previous posts in this thread from Team 1741. Could you please provide some context for your post? (What is your drivetrain; What feedback sensor are you using; How do you have it connected; etc) Thanks.
Additionally, are they in the same transmission? If so, then speed will be identical regardless of what each motor is doing.
The drive train is a 6 wheel drive. The center wheels are traction wheels. The front and back are omni wheels. All are driven from the center, which are direct drive. It uses two CIMs on the left transmission and two on the right transmission. One US Digital 250 CPR incremental encoder is used on each transmission. Each encoder is wired to the two Jaguars that drive the motors on the corresponding transmission. They are electrically isolated by opto isolators to prevent a ground loop. The PID speed control is done in each Jaguar independent of the other. The step commands are generated in software at 3 different velocities to help in tuning the PID loop.
I know the speed will be the same. That is why I posted the current graph that shows amps. This is where the unbalanced differences show up.
-Hugh
