Syntax Error
Im trying to compile my code in MPLAB, but when ever it comes to user_routines_fast.c it comes with an error
After the very end of the file, the compiler goes to the next line and then calls a syntax error. And if I comment that line out, it just goes to the next line and calls another error
How can i fix this?
It sounds like you’re missing a closing brace somewhere. Short of seeing the code, make sure every opening brace, has a closing brace… or that your last statement has a semicolon.
I checked all of that yet I am still getting an error.
It looks like this–
/* Add code to handle incomming data (remember, interrupts are still active) */;
(the code ends on the line above and a syntax error is being called on this line)
you’ve got a semicolon that’s uncommented, what happens if you remove it?
I tried that and it still doesnt work.
message sent.
sizolved.
