SysID characterization problem
We modified our shooter during the offseason and wanted to recharacterize but our SysID tests would run and not save. I thought it might just be a problem with what it’s displaying but when I try saving the data to a json and try opening it using the analyzer tool, the SysID tool crashes.
Here’s a video of what happens on the tool. (The jet turbine like sound in the video is the motor properly running the quasistatic test).
Here is the SysID command that has worked fine for us this past season to interface with the command itself. Here is the shooter characterization command we wrote that is being run in the video.
I’m not sure exactly what to do here because our characterization command has worked in the past and now it just doesn’t seem to end.
What version of SysId did you use? The version on main changed the NT handshake/sequence between the robot code and SysId.
I’m using the SysID that came with WPILib 2022.4.1 which I installed earlier than the version you linked. Will try the updated SysID tool the next time I’m with the robot and let you know how it goes.
