Yep. I’m a little concerned about the signal timing, though - on phoenix 6 there should be no appreciable velocity measurement delay, but yours is reporting ~160ms. The timestep versus time graph is very funky, too - what are your CAN frame timings?
Interesting. I havent changed anything from the default values.
I basically downloaded the SysId template and changed the code to work with falcon using voltage controlled output with no FOC.
This is all I am doing to configure the Falcon
configs::TalonFXConfiguration falconTalonFXConfigs{};
/* Configure the leader motor with the parameters stored in */
/* constants. */
falconTalonFXConfigs.CurrentLimits.StatorCurrentLimit = 40.0;
falconTalonFXConfigs.CurrentLimits.StatorCurrentLimitEnable = true;
falconTalonFXConfigs.MotorOutput.NeutralMode = ctre::phoenix6::signals::NeutralModeValue::Brake;
/* Apply the configuration changes to the motor under test */
/* controllers. */
m_motorUnderTest.GetConfigurator().Apply(falconTalonFXConfigs);
And this is the initialization of the sysid
/* Initialize the Falcons as the motor under test on the RoboRio's */
/* CAN bus. */
ctre::phoenix6::hardware::TalonFX m_motorUnderTest{kFalconMotorCanId, kFalconBusName};
/* SysId standard routine. */
frc2::sysid::SysIdRoutine m_sysIdRoutine{
frc2::sysid::Config{std::nullopt, std::nullopt, std::nullopt, std::nullopt}, // use default configuration
frc2::sysid::Mechanism{
[this](units::volt_t falconVoltage){ m_motorUnderTest.setControl(VoltageOut{falconVoltage, false}; },
[this](frc::sysid::SysIdRoutineLog *log){}, // log nothing, should be logged using URCL
this}};
Here is the source files if you want to take a closer look anything specifically:
Log was saved to flash drive (which was kind of an old flash drive if you think that could cause an issue).
I opened log in tuner X
regexprs for keys I need
exported out of .hoot to wpilog
Opened in advantage kit (to combine Wpilog with Hoot export so I could get the system base string and 1 file), which was my best guess of how to get it.
Opened in SysId, selected base string added MotorVoltage, Position, and Velocity then ran analysis. (also using SimpleMotorModel and Rotation units)
Also of note, this test was ran on an old RoboRio 1 we had available for testing off robot.
I can’t find any documentation on what the SysId parser might be expecting for this to be turned into so that my SignalLogger::WriteXXXX() can output the correct format for the state.
It doesn’t really say explicitly in the API documentation or the SysID page for FRC.
I took a peek at the wpilog file and it looks like maybe this needs to be a string written to the .hoot based on state. Something like “quasistatic-forward” etc.?
The suggested way to setup the CTRE phoenix6 SignalLogger to work with SysId in java is here.
There isn’t a C++ example (it would be nice if there was one, really, I don’t think it would be a huge effort to write) but I assume the process is the same, convert the enum to a string (using its name) and then write the string to the SignalLogger.
I don’t believe there is a specific SignalLogger function that accepts the enum directly, but WriteString does exist in C++ here.
We do not have a function that accepts the State enum as-is, but it should be as simple as calling frc::sysid::SysIdRoutineLog::StateEnumToString and passing that string to SignalLogger::WriteString.
Here is the log file .hoot and converted to .wpilog (which I dumped directly into SysID now that is has built in state information). LogFiles.zip (684.6 KB)
This looks like much more accurate data. The “sim velocity r^2” term is the real metric of overall fit quality to look at.
The decrease in the acceleration r^2 might be because the more-accurate sampling captures more high-frequency system noise that the model doesn’t account for, but i’m merely spitballing here.
I have a new flywheel mechanism today to characterize. This one is geared up 2:1 in attempt to get more speed. This one take a lot longer to spin up to full speed and I am back to having a negative Ks. (NOTE: I am using the same C++ software as I used to characterize the previous version).
The R^2 values seem to be in line, but it seemed like you also looked at some other numbers to evaluated how well it worked? I am curious which other values are most relevant to making sure the capture was successful.
Also when I used the Kp that was calculated for CTRE, it doesn’t like it at all. It oscillates wildly with that value (105.08) and any value over about 0.35. After further investigation, I am using VelocityVoltage type control, and I think when it is set to CTRE it is assuming DutyCycle units. Looks like (Pro) is using Voltage, so I will use that instead.
I would love your opinion on this data. Thanks Again!
Do not use the “CTRE” preset for Phoenix 6, those are the values used for Phoenix 5. Instead, you can use the default preset and change the “Controller Period (ms)” to 1.
Yes, I have a 35 A stator current limit. I can see that it does hit that limit as it spins up (thru telemetry on advantage scope). It is on a 40A fuse, is it ok to push that number up to a higher current limit? I wasn’t sure how much I could push the fuse before it turned off.
