System cannot find the path specified error inventor 2024
Hi guys! Our team uses autodesk inventor for CAD modeling, and when I installed a motor(775 pro) and configured it to our robot, it cannot be saved with the error “the system cannot find the file specified” with “the database in (file location) could not be saved”. I’ve searched on google for this problem, but it seemed that nobody else ever encountered this problem. I wonder if anyone has any insight into this.
Thanks!
I’m not a expert with Inventor but my immediate thought when seeing this would be whether or not the motor file is saved in the same folder as where the robot is saved. I would make sure the assembly and the parts that you are working with are all in the same folder.
k Ill try to fix it
thanks!
