Below is our configuration in system identification.
We confirm our gyro and encoders can work, but I have no idea why encoders get no value.
I think it can be a bug from sysid. My team had this problem, we run a different test and the encoder work it again, then we run back the test that was giving value 0, and it work just fine
What encoder are you using? How is it plugged into the Spark Max?
If you are using the neo integrated encoders you have to switch the encoder type from data port to encoder port.
But I think our data is inaccurate because Sim velocity R square is about -1.8. Can it be improved?
Your robot didn’t move during the dynamic test.
