Table of contents for FIRST-supplied Half-Field Drawings
I went through the Half-Field drawing PDF and made a table of contents:
pdf p. 1 Team Version Loading Bay-TE-20000, 1 of 16 (Overview and parts list)
pdf p. 2 Team Version Loading Bay-TE-20000, 2 of 16 (Exploded diagram)
pdf p. 3 Team Version Loading Bay-TE-20000, 3 of 16 (Assembly)
pdf p. 4 Team Version Loading Bay-TE-20000, 4 of 16 (Assembly)
pdf p. 5 Team Version Loading Bay-TE-20000, 5 of 16 (Assembly)
pdf p. 6 Team Version Loading Bay-TE-20000, 6 of 16 (Assembly)
pdf p. 7 Team Version Loading Bay-TE-20000, 7 of 16 (Parts Diagrams - TE-20000-01)
pdf p. 8 Team Version Loading Bay-TE-20000, 8 of 16 (Parts Diagrams - TE-20000-02)
pdf p. 9 Team Version Loading Bay-TE-20000, 9 of 16 (Parts Diagrams - TE-20000-07)
pdf p. 10 Team Version Loading Bay-TE-20000, 10 of 16 (Parts Diagrams - TE-20000-11)
pdf p. 11 Team Version Loading Bay-TE-20000, 11 of 16 (Parts Diagrams - TE-20000-08)
pdf p. 12 Team Version Loading Bay-TE-20000, 12 of 16 (Parts Diagrams - TE-20000-09)
pdf p. 13 Team Version Loading Bay-TE-20000, 13 of 16 (Parts Diagrams - TE-20000-03, 04)
pdf p. 14 Team Version Loading Bay-TE-20000, 14 of 16 (Parts Diagrams - TE-20000-05, 06)
pdf p. 15 Team Version Loading Bay-TE-20000, 15 of 16 (Parts Diagrams - TE-20000-Refl Tape,12,13)
pdf p. 16 Team Version Loading Bay-TE-20000, 16 of 16 (Parts Diagrams - TE-20000-10)
pdf p. 17 Trench-TE-20001, 1 of 12 (Overview and parts list)
pdf p. 18 Trench-TE-20001, 2 of 12 (Dimensions of opening)
pdf p. 19 Trench-TE-20001, 3 of 12 (Assembly)
pdf p. 20 Trench-TE-20001, 4 of 12 (Assembly)
pdf p. 21 Trench-TE-20001, 5 of 12 (Assembly)
pdf p. 22 Trench-TE-20001, 6 of 12 (Parts Diagrams - TE-20001-01)
pdf p. 23 Trench-TE-20001, 7 of 12 (Parts Diagrams - TE-20001-02)
pdf p. 24 Trench-TE-20001, 8 of 12 (Parts Diagrams - TE-20001-03,04)
pdf p. 25 Trench-TE-20001, 9 of 12 (Parts Diagrams - TE-20001-05,06)
pdf p. 26 Trench-TE-20001, 10 of 12 (Parts Diagrams - TE-20001-07)
pdf p. 27 Trench-TE-20001, 11 of 12 (Parts Diagrams - TE-20001-08)
pdf p. 28 Trench-TE-20001, 12 of 12 (Parts Diagrams - TE-20001-09)
pdf p. 29 Control Panel-TE-20002, 1 of 5 (Overview and Parts List)
pdf p. 30 Control Panel-TE-20002, 2 of 5 (Assembly)
pdf p. 31 Control Panel-TE-20002, 3 of 5 (Parts Diagrams - TE-20002-01)
pdf p. 32 Control Panel-TE-20002, 4 of 5 (Parts Diagrams - TE-20002-03)
pdf p. 33 Control Panel-TE-20002, 5 of 5 (Parts Diagrams - TE-20002-02)
pdf p. 34 TE Power Port-TE-20003, 1 of 16 (Overview and parts list)
pdf p. 35 TE Power Port-TE-20003, 2 of 16 (Assembly)
pdf p. 36 TE Power Port-TE-20003, 3 of 16 (Assembly)
pdf p. 37 TE Power Port-TE-20003, 4 of 16 (Assembly)
pdf p. 38 TE Power Port-TE-20003, 5 of 16 (Assembly)
pdf p. 39 TE Power Port-TE-20003, 6 of 16 (Assembly)
pdf p. 40 TE Power Port-TE-20003, 7 of 16 (Assembly)
pdf p. 41 TE Power Port-TE-20003, 8 of 16 (Assembly)
pdf p. 42 TE Power Port-TE-20003, 9 of 16 (Assembly)
pdf p. 43 TE Power Port-TE-20003, 10 of 16 (Parts Diagrams - TE-20003-01,02)
pdf p. 44 TE Power Port-TE-20003, 11 of 16 (Parts Diagrams - TE-20003-03)
pdf p. 45 TE Power Port-TE-20003, 12 of 16 (Parts Diagrams - TE-20003-07,08)
pdf p. 46 TE Power Port-TE-20003, 13 of 16 (Parts Diagrams - TE-20003-09,10)
pdf p. 47 TE Power Port-TE-20003, 14 of 16 (Parts Diagrams - TE-20003-04,05)
pdf p. 48 TE Power Port-TE-20003, 15 of 16 (Parts Diagrams - TE-20003-06,11)
pdf p. 49 TE Power Port-TE-20003, 16 of 16 (Parts Diagrams - TE-20003-Hook Tape, Refl tape)
pdf p. 50 Shield Generator-TE-20004, 1 of 8 (High-Level overview and component list)
pdf p. 51 Shield Generator-TE-20004, 2 of 8 (Overview and Hardware List)
pdf p. 52 Shield Generator-TE-20004, 3 of 8 (Measurements)
pdf p. 53 Shield Generator-TE-20004, 4 of 8 (Measurements)
pdf p. 54 Shield Generator-TE-20004, 5 of 8 (Assembly)
pdf p. 55 Shield Generator-TE-20004, 6 of 8 (Assembly)
pdf p. 56 Shield Generator-TE-20004, 7 of 8 (Assembly)
pdf p. 57 Shield Generator-TE-20004, 8 of 8 (Assembly)
pdf p. 58 Generator Switch Top Level-TE-20004-20, 1 of 20 (Overview and parts list)
pdf p. 59 Generator Switch Top Level-TE-20004-20, 2 of 20 (Measurements)
pdf p. 60 Generator Switch Top Level-TE-20004-20, 3 of 20 (Measurements)
pdf p. 61 Generator Switch Top Level-TE-20004-20, 4 of 20 (Assembly)
pdf p. 62 Generator Switch Top Level-TE-20004-20, 5 of 20 (Assembly)
pdf p. 63 Generator Switch Top Level-TE-20004-20, 6 of 20 (Assembly)
pdf p. 64 Generator Switch Top Level-TE-20004-20, 7 of 20 (Assembly)
pdf p. 65 Generator Switch Top Level-TE-20004-20, 8 of 20 (Assembly)
pdf p. 66 Generator Switch Top Level-TE-20004-20, 9 of 20 (Assembly)
pdf p. 67 Generator Switch Top Level-TE-20004-20, 10 of 20 (Assembly)
pdf p. 68 Generator Switch Top Level-TE-20004-20, 11 of 20 (Assembly)
pdf p. 69 Generator Switch Top Level-TE-20004-20, 12 of 20 (Assembly)
pdf p. 70 Generator Switch Top Level-TE-20004-20, 13 of 20 (Assembly)
pdf p. 71 Generator Switch Top Level-TE-20004-20, 14 of 20 (Assembly)
pdf p. 72 Generator Switch Top Level-TE-20004-20, 15 of 20 (Assembly)
pdf p. 73 Generator Switch Top Level-TE-20004-20, 16 of 20 (Assembly)
pdf p. 74 Generator Switch Top Level-TE-20004-20, 17 of 20 (Assembly)
pdf p. 75 Generator Switch Top Level-TE-20004-20, 18 of 20 (Parts Diagrams - TE-20004-01,02,03)
pdf p. 76 Generator Switch Top Level-TE-20004-20, 19 of 20 (Parts Diagrams - TE-20004-07,06,04,05,08,09,11,10)
pdf p. 77 Generator Switch Top Level-TE-20004-20, 20 of 20 (Parts Diagrams - TE-20004-12,13,14,15,18,17,16)
pdf p. 78 A-Frame Assembled-TE-20004-21, 1 of 5 (Overview and Components List)
pdf p. 79 A-Frame Assembled-TE-20004-21, 2 of 5 (Measurements)
pdf p. 80 A-Frame Assembled-TE-20004-21, 3 of 5 (Assembly)
pdf p. 81 A-Frame Assembled-TE-20004-21, 4 of 5 (Assembly)
pdf p. 82 A-Frame Assembled-TE-20004-21, 5 of 5 (Assembly)
pdf p. 83 A-Frame, Bottom-TE-20004-22, 1 of 10 (Overview and parts list)
pdf p. 84 A-Frame, Bottom-TE-20004-22, 2 of 10 (Measurements)
pdf p. 85 A-Frame, Bottom-TE-20004-22, 3 of 10 (Assembly)
pdf p. 86 A-Frame, Bottom-TE-20004-22, 4 of 10 (Assembly)
pdf p. 87 A-Frame, Bottom-TE-20004-22, 5 of 10 (Assembly)
pdf p. 88 A-Frame, Bottom-TE-20004-22, 6 of 10 (Assembly)
pdf p. 89 A-Frame, Bottom-TE-20004-22, 7 of 10 (Assembly)
pdf p. 90 A-Frame, Bottom-TE-20004-22, 8 of 10 (Parts Diagrams - TE-20004-35,36)
pdf p. 91 A-Frame, Bottom-TE-20004-22, 9 of 10 (Parts Diagrams - TE-20004-37,38)
pdf p. 92 A-Frame, Bottom-TE-20004-22, 10 of 10 (Parts Diagrams - TE-20004-39)
pdf p. 93 A-Frame, Top-TE-20004-23, 1 of 13 (Overview and Parts List)
pdf p. 94 A-Frame, Top-TE-20004-23, 2 of 13 (Measurements)
pdf p. 95 A-Frame, Top-TE-20004-23, 3 of 13 (Assembly)
pdf p. 96 A-Frame, Top-TE-20004-23, 4 of 13 (Assembly)
pdf p. 97 A-Frame, Top-TE-20004-23, 5 of 13 (Assembly)
pdf p. 98 A-Frame, Top-TE-20004-23, 6 of 13 (Assembly)
pdf p. 99 A-Frame, Top-TE-20004-23, 7 of 13 (Assembly)
pdf p. 100 A-Frame, Top-TE-20004-23, 8 of 13 (Assembly)
pdf p. 101 A-Frame, Top-TE-20004-23, 9 of 13 (Assembly)
pdf p. 102 A-Frame, Top-TE-20004-23, 10 of 13 (Assembly)
pdf p. 103 A-Frame, Top-TE-20004-23, 11 of 13 (Parts Diagrams - TE-20004-25,26)
pdf p. 104 A-Frame, Top-TE-20004-23, 12 of 13 (Parts Diagrams - TE-20004-27,28)
pdf p. 105 A-Frame, Top-TE-20004-23, 13 of 13 (Parts Diagrams - TE-20004-29,30)
pdf p. 106 Hard Stop Assembled-TE-20004-23, 1 of 5 (Overview and Parts List)
pdf p. 107 Hard Stop Assembled-TE-20004-23, 2 of 5 (Measurements)
pdf p. 108 Hard Stop Assembled-TE-20004-23, 3 of 5 (Parts Diagrams - TE-20004-32,33)
pdf p. 109 Hard Stop Assembled-TE-20004-23, 4 of 5 (Assembly)
pdf p. 110 Hard Stop Assembled-TE-20004-23, 5 of 5 (Assembly)
pdf p. 111 Front and Back Plate-TE-20004-41, 1 of 1 (Part Diagram - TE-20004-41)
pdf p. 112 Side Plate-TE-20004-42, 1 of 1 (Part Diagram - TE-20004-42)
