Talon SRX and Hall effect sensor as limit switch
We are considering using two hall effect sensors as limit switches. We would like to connect the sensors directly to a Talon SRX. The Hall Effect sensors we are looking at (US5881LUA) require 3.5 V to 24 V and typically draw 2.5 ma ($2.00 devices Hall effect sensor [US5881LUA] : ID 158 : Adafruit Industries, Unique & fun DIY electronics and kits, data sheet: https://cdn-shop.adafruit.com/datasheets/US5881_rev007.pdf).
These sensors work fine as a DIO input on the roboRIO where the roboRIO supplies the sensor with 5V of power.
From the Talon SRX documentation, most of the diagrams I see show the limit switch connections involving two wires (basically closing a connection between ground and the limit switch input).
Forgive my ignorance here (I’m a programming mentor), but is it OK to connect these type of powered of sensors as limit switches directly on the Talon SRX?
I’d like to make the following connections:
  • 5V from pin 2 on the Talon SRX to the Vdd on the sensor
  • GND from pin 10 on the Talon SRX to GND on the sensor
  • Vout from the sensor to pin 4 on the Talon SRX (Forward Limit)
  • A 10K ohm pullup resistor across Vdd and Vout
I’m hoping it’s OK to do this. I think that’s what this statement in the User’s Guide is telling me::
Attach the Forward/Reverse Limit Switch as shown. Do not connect the GND elsewhere. The Talon
SRX provides a pull-up to 2.5v, so typically an external pull-up is not needed. Only use Talon SRX
3.3V or 5.0V power if an external pull-up is used.
If anyone could confirm that this is OK to do, or warn me that I’m about to melt my Talon, I’d appreciate it.
This is just a follow up. We experimented with wiring a powered sensor as a limit switch to the Talon SRX last night and it appears to work. Once the magnet was within range of the hall effect sensor the Talon SRX responded with the red LED signal.
