Do you guys know if it is possible to use the navx with the talon srx built in pid?
Thank you.
Thank you.
I don’t believe so in the sense of plugging a NavX into the TalonSRX to run a PID system, but one thing that is possible and has been done many times before is using heading/yaw data from the NavX to turn the robot, but this requires a bit of code and is not a “built in” functionality. Hope this helps!!
I did not mean to plug the navx directly into the talon. I mean to use the data sent by the navx like the yaw angle as the control feedback for the talon built-in pid. I guess it’s not possible.
In most cases, full PID control won’t be necessary and P alone is enough. You can write your own P controller quickly and easily:
yawError = targetYaw - gyro.getAngle();
yaw = kP * yawError
The yawError
is the difference between the set point (targetYaw
) and the current position. Then multiply the error by the proportional gain (kP
) to get the controller output, yaw
Unfortunately I do not think it is possible. Perhaps you can use the MotionProfileArc control mode with the CTRE Pigeon IMU.
huuh ok. I wanted to use the magic motion feature of the talon, I guess I would have to implement my own. Thank You though!
