Talon Tach as switch
We are using the Talon Tach as a switch, however we can not get it to sense whether it is open or closed. When it is connected to the Talon SRX, through the data port, the indicator light on the Talon Tach does go on and off. However, in code and using the webased config tool it only shows that it is always open. What’s up?
Did you bridge one of the three selector pads on the circuit board? Looking at the manual, you need to apply solder to the selector pad for whichever mode you want to use. For you, that would probably be a forward limit or reverse limit.
:wink: Dah… that was it. I know, read the manual before asking the question.
