Target Ip address
How and where do you set the target ip address in the java code?
In NetBeans:
Tools > Options > Miscellaneous Tab > FRC Configuration Tab
Team Number is the first field, and the only one enabled by default. Once you type your team number in, hit OK.
It seems to take a weirdly long time to update.
After you’ve done that, the plugins should have the right target.
already got it. ty
