Tasks Question
Iv got a task running and i have a problem.
I cant control anything that isnt static, like solenoids and such. Any way around this?
I’m not exactly positive what you’re asking, but this thread might help you out: http://www.chiefdelphi.com/forums/showthread.php?t=82398&highlight=task+tutorial
Thanks, that helped quite a bit.
Though now im having a separate problem with it. When i declate the task:
Task scissorLiftTask("Scissor Lift Task", (FUNCPTR)scissorMovePos);
I get the error
error: argument of type `void (BuiltinDefaultCode::)(int)' does not match `int (*)(...)'
My function for the task is as follows:
void scissorMovePos(int argPtr)
		ScissorsLiftTaskStruct* args = (ScissorsLiftTaskStruct*)argPtr;
		while(true)
			if(curPOS != POS)
				switch(POS)
					case 0: // DOWN
						args->solenoids[1]->Set(true);
						break;
					case 1: // SIDE HIGH
						break;
					case 2: // SIDE MID
						break;
					case 3: // SIDE LOW
						break;
					case 4: // MID LOW
						break;
					case 5: // MID MID
						break;
					case 6: // MID HIGH
						break;
					default: // DOWN
						break;
				curPOS = POS;
EDIT:;
Also, im getting this error:
error: incompatible types in assignment of `Solenoid* (*)[9]' to `Solenoid*[9]'
with this line:
scissorLiftTaskArgs.solenoids = &m_solenoids;
Declarations of the two objects involved in the above error:
struct ScissorsLiftTaskStruct
	     Solenoid *solenoids(NUM_SOLENOIDS+1)];
Solenoid *m_solenoids(NUM_SOLENOIDS+1)];
