Team 1989 sliders 3d printed for 20mm T slots
Also Nylon we use graphite to make it slide even better
RackMetalDevice2.0-04-1in_wide.ipt (436 KB)
RackMetalDevice2.0-04-1in_wide.stl (50.7 KB)
RackMetalDevice2.0-04-6in_wide.ipt (436 KB)
RackMetalDevice2.0-04-6in_wide.stl (124.5 KB)
Again you want to adjust this to be tight enough to reduce wiggle and loose enough to slide print upright with a big brim to keep them attached to the build plate
Have you heard from Teflon spray? Works wonders on this stuff
Will have to check it out
