Team 2200 - Autonomous
http://youtu.be/9YbXu0Wuz0s
See you on the field!
How come you guys only shot 2?
That run was setup for shooting from the close side of the pyramid. In that case we would only be allowed to preload 2 discs.
Im not following…
If you are not touching carpet outside of the auto zone you may only load 2 discs to start the match.
G06
TEAMS may preload White DISCS in or on the ROBOT before the MATCH.
If the ROBOT is in contact with any carpet outside its AUTO ZONE, the ROBOT may preload up to three (3) DISCS.
Otherwise, the ROBOT may preload up to two (2) DISCS.
Wow, I never saw that rule.
