Team 2620 Teaser
Here is a side view of the bottom of our bot :wink:
It turned side ways when I uploaded it for some odd reason, but yea
Looks like an interesting way to change the angle or potentially hang for 10?
We’re going for 30 point hang, she has climbed on her own but we’re optimizing it a bit more to make it more stable
Tip the bot so you can climb the corner, of course?!
Is that sprocket direct driven from a motor pinion or is there some kind of worm gear? Thanks for sharing!
A window motor is powering it as a worm gear :wink: And as we climb the tower, the base has to be level to grab the next level so, we push the back end up!
Added another teaser!
My source code for the robot :wink:
http://www.chiefdelphi.com/forums/showthread.php?p=1237339#post1237339
