https://music.youtube.com/watch?v=gnzgkx6jE1A&feature=share
A basic overview of what we have CADDed so far. The intake for floor loading cones isn’t a real thing yet, nor is the “cone scooper” which is supposed to get the cones up off of the ground once they are in the robot.
Some on the team seem to think they won’t bother with that until after their first competition.
This shows the arm in the upright position. The plan is for the arm to telescope out to put cones on the higher levels of the grid.
The frame so far. So many steps forward followed by so many steps back?
A closer look at the arms.
The arms partially extended. The gripper isn’t mounted yet because we don’t have the right type of linear bearings. We will probably make a temporary mount to get us through until the bearings come in early next week.
This shows the prototype for the gripper. The actual gripper uses sloped slots which allows the motion of the arms to be smoother. Eddy also made the slots closer together so the robot would be able to clamp down on cones and cubes more easily.
This shows the baseplate we will actually be using on the robot. You can see that the slots are rounded instead of straight. This is supposed to make the movement smoother. Eddy did the CADD for this and didn’t share it with me so…
This is the gear box setup we will be using to rotate the arm. We may mount a large weight behind the motor in order to balance things out and lessen the load on the gearbox as the arm rotates depending on how much weight allowance we have. I joked a while back about using the battery as a counterweight…I’m not saying we actually plan on doing that but…
Ok…so where are we and how do I feel at the moment?
I went into today having the following thought…"The team is stalling out.
While that was true two things also happened today which made today much less productive than normal.
First, there was a band competition today? Kids in band played music for judges…So…a large number of people didn’t show up for robotics today.
Second, the kids built a wheelchair ramp for a family in town. While we normally try to resist taking on special projects like this during build season, this was an emergency that needed to get taken care of in a hurry. They needed the ramp yesterday and it was a small one that we could build quickly.
But…None the less, the team has largely stalled out and stopped making much forward progress.
So…a huge part of the problem:
Our school got a CNC plasma cutter.
I have wanted one for years. I was repeatedly told that I couldn’t have one because I didn’t have room in my classroom.
I asked if we could put it in the metal shop teacher’s classroom. They said no.
I asked if we could put it on wheels and store it outside, or if we could build an outdoor workspace solely for holding the plasma cutter, or if we could put it in the art departments out door covered cage area so they could use it…No…No…No.
SO…last summer the metal fabrication teacher finally gave in and got one.
The company came out and set it up over winter break.
Now to be honest, it isn’t the best at cutting aluminum…but…it works, and it works quickly. The cutting envelope is way bigger than anything we will ever need for FIRST, (probably shouldn’t say that) and it is really fast and wonderfully accurate.
So…the reason why it is a problem…
In years past we had a group of kids who spent all their time doing CADD. We had another much larger group of kids, (Almost everyone) who could use a bandsaw and drill press to make just about everything. We would print out a part on paper, and they all knew how to glue it down on metal and cut it out.
We used other tools also, but you get the point.
Thing is, the plasma cutter cuts out all of the kids who aren’t CADDing.
We go straight from the computer to a part with just a little bit of filing and chasing some holes.
You have been replaced by a robot.
So…things are going really fast, but most of the team is left with very little to actually do. But here is the really hard part.
The only stuff that is left is the really really really hard stuff.
The, things moving around things type stuff.
So…The team has stalled out.
Today Conner spent hours staring at an intake design that Branson started over a week ago, and he basically just sat there looking at it trying to figure out how to mount it on the robot despite the fact that as it was currently designed it would not work. at least he tried.
There is a kid on the team. She is taking college classes while in high school through our schools “running start” program. Kids can take classes at our local community college while in high school.
So…she doesn’t show up very often.
For kids who don’t show up very often there are two paths. One group will come in and immediately start asking for things to do.
The other group comes in, maybe looks around, and doesn’t engage at all. They sort of sit and wait for someone to ask them to do something, and since CNC plasma cutter is doing almost everything besides CADD work, the group that waits just keeps on waiting.
Today during lunch she was watching an interactive barbie movie on netflix. Some other people from the team joined in watching. Lunch ended up running long, then most of the team had to go install the wheelchair ramp. She has a vehicle, so she took a bunch of people over to work on the ramp.
They put the movie on the large screen at the front of the room, and paused it right before barbie finally kissed ken on the Ferris wheel.
So…oddly, a whole lot got done while not much got done all at the same time. It sort of broke my heart a bit. More time does not mean more productivity. More people does not mean more productivity. More does not = more…except maybe more passion, or more dedication…
I fear that at some point in the relatively near future the kids will wish they had more time…just a few more hours.
Thing is…I could have put a stop to it. I could have put my foot down, but until someone is willing to tackle the harder problems then it doesn’t really make much of a difference now does it.
Meh…We’ll see tomorrow I guess.
Oh…I forgot to post this. It is a link to a folder with our current CADD model and all of the assets as an inventor pack and go:
https://drive.google.com/file/d/1HdIMgWcWTn_J55LoKuoY-BDPYghuQBsy/view?usp=sharing
Enough for now.
Edoga
