Hi everybody,
We know, the design isn’t the most common one…
But we weren’t sure that we will be able to shoot accurately, so we chose something simpler.
We will be able to pick up balls from the ground, lift them, and score to the middle hoops. http://img651.imageshack.us/img651/3968/roboty.jpg
Comments? thx
Team 3316
By the way, we are still working on the bridge pusher. We ran some tests, and the window motor isn’t strong enough, and even the van door motor has troubles… What motor do you guys plan to use for this task?
pretty cool. we tossed around a simular idea, but in the end oped to go with a shooter. do you have any video you’d be willing to share? i’m quite curious to see it in action
Thanks a lot guys!
I am quiet surprised to get such encouraging comments, it really made my day
pretty cool. we tossed around a simular idea, but in the end oped to go with a shooter. do you have any video you’d be willing to share? I’m quite curious to see it in action
We don’t have a video yet, but I’ll post it as soon as we will have one.
One thing, though. The bumpers are gonna add another 2 inches in front. Just hope that doesn’t kill your dumper at the end of the day.
Very good, job. Even if you are just going for the second hoop, from experience, I know that there will be many teams who have a shooter, but are a lot less consistent than you. Especially good job deciding to go with the simpler, design.
The robot looks great, my team used the same concept for VEX Gateway this year and it worked great. I just wanted to make sure that you guys had looked into rule R02:
**[R02]
The Robot must satisfy the following size constraints:
a.horizontal dimensions must not exceed 28 by 38 in.,
b.the absolute height must not exceed 84 in.,
c.the height of the Robot at the start of the match must not exceed 60 in.,
d.any appendage may not extend more than 14 in. beyond the frame perimeter, and
e.no other part of the Robot may extend beyond the vertical projection of the Frame Perimeter (with the exception of minor protrusions permitted per [R01-2]).
Specifically, d and e. When your arm is going up, it is going way out of the 14" allowed from the perimeter.
Dont see how since it looks to lift vertically. The piece doesnt move horizontally so it would be the same amount outside the entire way up.
Correct.
The ball holder is lifted vertically, and then turned to almost 90 degrees. Therefore, it will not violate R02, and will only be something like 13’’ outside the frame perimeter.
but thx for your concern
I am very happy to see a robot like this come together. A big part of being successful in FRC is recognizing your team’s limitations. It seems to me that you thought you could make a better robot that could do the 2 point shot than one that could shot balls from all over the field at the top hoop and I commend that approach. I look forward to seeing your progress this season and wish you guys the best of luck.
I dont know their name, but we are using I think a Banebot with one of those big huge plastic gearboxes (The ones that are normally used on kiddie electric plastic car/jeep thingies)
