Im hoping you positioned the pyramid PERFECTLY! because if not that would be horrible to hit the poles. Also if you were to shoot them from the feeding station, into the 1pt goal for a total of 51 points, what does the 2 other robots do? together 3 robots scoring the 51 discs into the 3pt or 2pt goal could get alot more points
Yes, our pyramid is positioned correctly. We triple checked that today.
That, we’re unsure of. Really each match will be different, we can reach all three goals, and it comes down to what works best with our different alliances during qualifications and who we’re up against.
And with that disclosed information, would you mind gathering the start up time of your shooter as well? (How long it takes until the shooter is running at its full speed.) It’d be greatly appreciated.
Just to answer some questions. Our shooter is a 90 degree bad boy. Pictures of the custom transmission used to power it have been posted a few days ago, so feel free to check those out.
The start-up time is about 2 seconds.
Honestly, it’s nothing more than a combination of a number of designs posted on CD over the past two weeks. You will see once we have the actual final version ready. Until then, just keep trying. It’s easier than you think.
Well then obviously the full court shooting will not be a strategy we can use in that match. We’ve tried to see for both high and low goal how close and how far away we can be and still make it in and are giving all this data to our programmers.
