I noticed that as well. It almost looks like they attempted to shoot high in the beginning. Had issues with their shot and ultimately decided to shoot low as it would gross them the most points.
That hood (or entire shooting apparatus) appears to be able to actuate. Pneumatic cylinder or something. Is that for your climb? Other things in mind? Or perhaps my eyes are fooling me.
Also, hello from your neighbors! Our robot is not nearly as impressive as yours, in it’s current state.
Edit: I just noticed the two comments above me, the problem with getting distracted with work things partway through composing a post. (I was thinking maybe high goal as well, just that angle is strange. Could just be perspective.)
The hood assembly does actuate up and down via pneumatic cylinders, this holds two purposes. First is to actuate our climb out and the second being to feed other teams over their hoppers.
Nice looking robot this year, I’m curious about your active gear delivery, do you have any additional images or description of the system, it appear to be two L-shaped pivots actuated pneumatically?
Looks nice, but it also looks like you have stuff outside your frame perimeter and doesn’t look like it started inside. Specifically the air tank and it looks like the uprights are canted outward over the bumper. Remember, at start of the match, everything except bumpers needs to be inside the frame perimeter, not just inside the max volume.
I’m assuming that’s because this is the “expandable” hopper - it starts the game inside the frame perimeter, then expands out once the match is started.
The Hopper expands over the bumpers using a four bar linkage and surgical tubing and starts the match fully inside the frame. This picture was taken of our practice bot which has a older version of the hopper. On our comp bot we have nylon webbing hard stops that stops the hopper from expanding past the bumper.
Congratulations Dave yet again on an amazing build season! Can’t wait to see you guys compete this week and cheer you on as you progress through this season.
P.s Danny I love the signature, we all know Sven is clearly your favourite Dave mentor
The gear enters the cage via a pneumatically actuated ramp and sits snugly between two c shaped claws. The claws are pneumatically actuated around a pivot point which forces the gear out of the robot and onto the peg. http://imgur.com/R6Qwbyb
