a total render time of 80 hours on 8 seperate computers
watch and see the magic
sorry it said the 1.8 mbs zip file was too big to post…i’ll try to get it up soon
Our animation took 36 hours to render on 60 computers
LOL, it only took two computers and a total of 20 hours to render, LOL
Wow, our animation took about 15 hours to render on about 9 different computers. We didn’t network render though because with the network setup we had it proved to be a pain. I ended up re-rendering a couple of parts here and there though so I am not sure if you guys are figuring that in or not.
Is there a link for your animation or do i have to go searching?
we did not net render…we had 8 computers and 4 cameras to render each had 900 frames…so if you do some math you will see that it was about 450 frames per computer…each camera was cut in half. each comp took about 10 hours per comp…
i made it as detailed as i could each and every wire is in the correct place, although you would need to look at each frame for a second or two to see them.
here it is, its in a yahoo briefcase, tell me if this does not work
Good animation.
