Team 846 Dual Falcon Swerve
Dear All,
Team 846 is proud to share the design for the swerve module that we have been working on.
Specs and Features:
Geared to 15.18 fps(theoretical)
Weight of 6.3 lbs
Dimensions of 5.5"x7"x9"
2.3125" Ground Clearance
Total Reduction of 23.5:1 for the swiveling motor, which is low, but the Falcon should have more than enough torque with this reduction for this application
MA3 Encoder Geared 1:1 to wheel rotation
The Falcon 500 used for swiveling can be easily replaced by a CIM or NEO, but the one used for driving can’t due to the Falcon’s significantly higher RPM
Attached is the CAD file, as well as a spreadsheet documenting the reductions
846_SwerveAssembly.x_t (32.7 MB)
Swerve Gear Reductions.xlsx (11.5 KB)
It might just be me, but it says your file is private or missing.
I changed the file and updated this thread. Try downloading it again, and if that doesn’t work try using this link: https://grabcad.com/library/846-swerve-module-1
Please let me know if you still run into troubles
Why do you have a MA3 Encoder if the Falcons have an integrated encoder?
Could be a preference thing. I know having an encoder directly on the wheel rotation is easier at least IMO then it being before all of the reduction in the motor. Completely a preference thing though.
The Falcon encoder isn’t 1:1 with module steering angle.
You either need to index somehow with another sensor, start the match in a known location, or have an absolute sensor 1:1 on the module.
I’m excited to see this on your 2020 robot!
Go bananas!
No worries if your 2020 bot ain’t swerve but a monkey swerve would be amazing
It is a lot easier if the encoder has a 1:1 relationship with the angle of the wheel, so software doesn’t have to track all the rotations and do a bunch of math
Thank you!!!
Monkey… Funky Monkey… Mighty Monkey Wrenches… (Just a few that i know off my head)
