check it out:
http://chargersrobotics.com/images/teamlogo.jpg
We may have to simplify it a little bit(less gradient/shadow) for our shirts, though.
Always love feedback.
check it out:
Itās interesting.
Iām guessing you used the beveling feature in photoshop? Tone it down so that maybe only the outer edge is beveled and raised.
You may want to rethink the black background. Work with your logo with the mindset that itāll be on a white background. That way, the end product will be a bit more versatile.
The font doesnāt really catch my eye, but the general setup seems nice.
You can probably get away with making the ābrush strokesā behind the oval into one solid color and still get a cool effect.
Push the text up so itās closer to the team #.
Thatās my two cents.
Do you mean on the letters? Thatās the Satin layer effect. I will however, take a look at it with a bevel like you mentioned.
Perhaps if there was more space under the text, do you think that would also work?
Iām gonna play around with it on a white background as well.
Thanks for the input. Itās greatly appreciated.
I think it looks pretty good. I like the color scheme.
I would suggest changing the text font or spacing⦠the numbers are pretty readable from a distance, but the āchargers roboticsā kind of blend together making it hard to read.
Edited it around a bit.
black bg: http://www.chargersrobotics.com/images/teamlogo2.jpg
white bg: http://www.chargersrobotics.com/images/teamlogowhite.jpg
Iāve spaced the letters of āchargers roboticsā and went with a simple bevel on the 894. On the white one, the scratched up shadow thing is now just a fading blur shadow thing.
The text looks better
The more prominant āshadow smokeā thing going on in the black version is really nice.
Too much space!!
It should be as compact as possible while still keeping itās cool.
On lighter backgrounds, you should definately make a version where the oval has a black outline. If anything, thicker outlines on both the text and oval.
You may want to actually want to go ahead and make two versions which cater to both backgrounds for future use.
FYI, as for shirts, unless you get a good (albiet expensive) printshop, they will probably ask for all solid colors.
Defiinately an improvement in my opinion! Just a few changes and it can be DEADLY.
