check it out!
Can I get any feedback please?
1.) Frames are too big. While frames can be done correctly, I’m not a fan of them. That’s just me. I’d use the top frame for more information and make it smaller, and get rid of the whole bottom frame, most of that info can be put on the bottom of the page with most of the information.
2.) On the navigation top, some of the links end up on another line, try to fix that.
3.) Good team info section
4.) Make the middle frame bigger.
5.) What’s your team nuber? I don’t see it on the page on top, or anywhere else, you might want to add it so it’s easy to see.
Thanks for the feedback.
[quote]1.) Frames are too big. While frames can be done correctly, I’m not a fan of them. That’s just me. I’d use the top frame for more information and make it smaller, and get rid of the whole bottom frame, most of that info can be put on the bottom of the page with most of the information.
There’s only one frame. The top and bottom are all part of the index.html page, while the iframe is within the index.html page. That way, the banner and such is only loaded once. [/quote]
But it gives the same effect as a top, middle and bottom frame.
[quote]2.) On the navigation top, some of the links end up on another line, try to fix that.
That would be because your font size setting is higher than normal. Try pressing Control+0 if you’d like to see it on normal size. [/quote]
You should try to make websites that work with everything - as in it doesn’t matter what font size the person uses.
