Did not know if there was any team out there that would be willing to help a struggling team. It is our first year back in a couple years. Our programmer is no longer with us. We are a very small rural team.
What we are looking for is some to write a simple code for us. We currently are using an old code that was on the RoboRIO to test items.
What we need is the following:
2 joysticks
1 to drive in Mech
1 to operate everything else.
Joystick 1
Mech Drive is 0-3 PWM slots
joystick 2
Arm Motor - on y axis of joystick
button to run a motor one direction
same button to run a motor the other direction
button to turn motor on and run in one direction
button to run 1 or 2 double solenoid
button to run 2 of 2 double solenoid
button to run 1 of 2 single solenoid
button to run 2 of 2 single solenoid
We are using Sparks motor controller
I am sure some one will ask us to post what we have, we have NOTHING.
“Drive in Mech” you mean Mecanum? If so a lot of teams do strafing side to side and either use a joystick that has a z axis or use something like an xbox controller and use the bumpers to rotate while left/right strafes.
Joystick 1:
Which wheel is which PWM?
“button to run a motor one direction
same button to run a motor the other direction”
Does this motor run continuously? If not what stops it. Time? Usually better to have different directions on different buttons IMO. You can then decide to either button press on button press off or hold on release off or on press run for X seconds
“button to turn motor on and run in one direction”
Same as above what stops this motor?
Do you have 4 solenoids? Same as above what turns these off?
Do you have a programmer that is interested in learning and hasn’t or do you have nobody?
I would feel more comfortable doing this with someone watching both for feedback and so that they could learn.
yes Mecanum
all we have is logic joystick
right front PWM0
right back PWM1
left front PWM2
left back PWM3
button to run one motor - yes when the button pushed it should run in one direction continuously until we let go of the button
yes same as above to second motor
we have 4 solenoids
2 doubles
2 singles
letting off the button should shut them off.
no their is no one else. we are very small and we have had about a total of 3 weeks off school and we can not pull any one off. we are not going to be ready for stop build day anyway.
can you please send a link with the controllers (joysticks) you have?
So I am seeing the need for:
Joystick 1:
1 button to rotate left (on drive joystick)
1 button to rotate right (on drive joystick)
Joystick 2:
Y axis runs Motor 1. Deadband here? Scaling?
Run Motor 2 Positive on while pressed
Run Motor 2 Negative on while pressed
Run Motor 3 Positive on while pressed
Solenoid 1 out while pressed
Solenoid 2 out while pressed
Solenoid 3 forward while pressed, reverse when released
Solenoid 4 forward while pressed, reverse when released
Do you have more descriptive names for any of: Motor 1, Motor 2, Motor 3, Solenoid 1, Solenoid 2, Solenoid 3, Solenoid 4?
Joystick 1 - the following means it is mecanum control? If so, then yes you are correct.
Joystick 1:
Joystick 2:
Keep in mind I have set some basic motor numbers in general I kept things at 20% Power & -20% Power. You can go in and adjust those power levels by changing them to a number between 1 and -1 for 100% and -100% respectively.
Good luck and let us know how it goes! If you have specific questions about it PM me and we can talk via phone or something.
Additionally, if you’re up for it, I have a GitHub RecruitRIO program that I keep to teach my code team.
I’d highly recommend you check out the examples in there, as they are quite helpful and how I mentored my team in Java. I hope it helps and I wish you the best in the future!
