I’m especially impressed by how it can take a passed ball from the loading station. That could lead to some scarily fast cycle times.
#translatorclimbgang
Love the design and watching y’all this week! Would you mind telling what those cool green wheels are (Material, Size)? I’ve never seen anything like them in a flywheel shooter before. Thanks and gl @ Clackamas!
Those are green 35A stealth wheels (basically compliant wheels with a solid plastic core and a thin rubber coating)
Oh, interesting, and thank you. Did the flywheel rpm/compression drive the choice of wheel?
I can’t speak for 2471, but with soft balls like these, you want a hard wheel, and these are as grippy as compliant wheels with nowhere near the level of expansion under high rpms.
Definitely seems urethane with a solid hub and that big weight is a very solid option, allows for lots of freedom with rpm and good grip; it works beautifully here. My only concern would be glazing, but the wheels are cheap and easy to replace compared to something like colsons or a tight hub for fairlanes. Thanks again!
