To further elaborate and provide some context:
We (speaking for 1619+254 from here on when I say “we”) were very comfortable playing with either 6672 or 3175 on our alliance. Both were great robots and great to work with. But they brought slightly different things to our alliance.
We had great confidence that both partners would play awesome defense when called upon, and they did. 6672 brought the triple traversal capability, and could shoot from further away, while 3175 brought a reliable fender shot and the ability to do more with opponent balls.
We chose these teams because we wanted the option to play either a triple offense or 2+1 configuration with either team. Both robots were extremely high quality and we were confident they could survive the meat-grinder of Championship eliminations. In division elims we played one match with each third robot, to try things out and assess chemistry, and both partners absolutely rocked it - so we decided to go from there primarily with 6672 because of the triple traversal (which we knew would be important should we make it to the Round Robin, since hangar points are the first tiebreaker). We played a version of triple offense (where 254 also targets opponent balls to lob back to our side of the field) throughout division elims, mostly to see if there was a variation of it that could overpower an opponent playing heavy defense. While we won all the matches, things were tight enough (and the other Einstein alliances strong enough) that we were not confident that this configuration would be successful subsequently, so we switched to a more conventional 2+1 from there.
So we switched to a 2+1 configuration, leaving in 6672 to maximize endgame points, throughout the round robin. This was absolutely the right move, as we were able to defeat 3 of our first 4 opponents thanks to their defense (despite a lot of autonomous problems on these unfamiliar fields) and had built a healthy lead in hangar points. Going into our last match, we actually discussed possibly just hanging immediately in the match to clinch the tiebreaker, but decided instead to play conventionally and just go for the endgame with an extra time buffer (which took away our defense and scoring earlier than usual), so we were not overly disappointed by that loss (still, full credit to the Carver champions for beating us!).
In this configuration, we split the field in a “hamburger” style between the scorers: 254 took the far side and 1619 the near side. We believed this played to the teams’ strengths. The drive coaches could call for a rotation to “hot dog” or to switch sides if needed to peel away from defense (and we did rotate for a bit in some matches).
In the finals, we decided to go with the same configuration that worked well for us through the round-robin, since it was a known quantity and had already defeated the Turing alliance. Finals 1 was a one-point win (that has been extensively discussed) despite a catastrophic failure in autonomous by 254, so we went into Finals 2 with largely the same plan, hoping that auto would not fail in the same way and build a bigger point differential (in addition to some subtle tweaks: 254 trying harder not to get pinned by 4099 and 6672 trying to defend 1577 for longer before the endgame, being willing to forego the triple if necessary to take easy balls off the table for the opponent). Had we lost Finals 1, I think we absolutely would have called the audible we made in Finals 3 earlier.
Finals 2 made it clear that Turing had our number and we had to change things up. We made the following changes for Finals 3:
- We switched driver stations and offensive zone responsibilities between 254 and 1619, putting 254 on the left and 1619 on the right. 254’s zone was the left and near 3/4 of the field, with 1619’s being the far hangar. We were gambling that either 4099 would switch to defending 1619 and largely take them out of the match (and hoping that 254 would run free and score ~30 balls in teleop to compensate), or that 4099 would follow 254 to the far side, where visibility was more in our favor and we also had the benefit of the launchpad. Note that this configuration was not compatible with our triple traversal due to sightlines anyhow, so we had full choice of third robot.
- Putting in 3175, so that we could hold 2 opponent cargo and also just throw a changeup at the opponents.
- Tweaking 3175’s defensive responsibilities to be still focused on 1577, but to opportunistically defend 4414 especially in the endgame (we suspected 4414’s climb had been damaged after they didn’t attempt it in F2).
Our F3 configuration was clearly the right move. 3175 has ice water in their veins. Before we made the call, I remember asking Jason (their drive coach) if they were up for this, and the calmness and confidence in his eyes and voice told me everything we needed to know.
All in all, this was probably the strongest 4-team alliance I’ve ever been a part of in FRC.
