Teams 1923 & 1914 The MidKnight Inventors 2022 Robots - Outrage and Uproar
What is Project Gemini?
Prior to the start of the 2022 season the Student and Adult leadership of Team 1923 decided that in the interest of increasing student involvement we would start a second FRC team to help give our 170+ students more opportunities to actively participate both at home and at competitions. However, in breaking with the typical dual team models in FRC, Teams 1923 and 1914 are one and the same in that all MidKnight Inventors are registered members of both teams. The team has built 3 identical robots, one competition robot for each team and a third practice robot that is used for programming and development. At competitions each team will have a separate and distinct four-person drive team, but beyond that all work on the robots as well as scouting and strategy will be done collaboratively between both 1923 and 1914 by MidKnight Inventor students. We are excited to provide our students with more opportunities and hope that this improves the competition experience for our rapidly growing team. With that being said…
FRC Teams 1923 and 1914, The MidKnight Inventors are proud to present our 2022 robots: Outrage & Uproar
Robot Highlights:
  • Full width, passively deployed Cargo Intake
  • “Underhand” Launcher with powered hood rollers
  • High Rung climber with potential to complete the climb after the buzzer
  • Heavy use of laser cut Delrin and Chromoly steel with Markforged 3D prints
  • No Pneumatic system
Primary Design Constraints:
  • Easily travel anywhere on the field
  • Small footprint for maneuvering in tight spaces
  • Rapid intake of 2 Cargo
  • Accurate scoring in both the Low and High goals from the fender
  • Fast Mid Rung Climb with potential for further Rungs
  • Easily serviceable design
Drivetrain:
  • Custom 2-stage single speed flipped 3 Falcon 500 gearboxes utilizing laser-cut Delrin faceplates and Markforged spacers with embedded standoffs
  • Gearboxes geared at 9.1 : 1 ratio for a theoretical free speed of 15.3 fps
  • Flat, 6 wheel, west coast drive including:
    • four 5” Colson outer wheels, with custom cut treads
    • two 4.75” Colson center wheels
  • 24” x 27.5” sheet metal WCD chassis with chain running on the cantilevered wheel side for ease of service
  • .125” Delrin bellypan with .050” Chromoly steel reinforcement
Intake:
  • Passively sprung double jointed intake utilizing gas shocks and surgical tubing deployed at start of match by rolling leading roller over a wheel chock
  • Delrin and Polycarbonate construction reinforced with Chromoly side-plates
  • Rollers made up of 72 2” Flex Wheels on thunderhex shaft
  • Designed to collapse on impact to prevent permanent damage
Launcher:
  • Full width “Underhand” Launcher optimized to score from the fender
  • Launcher constructed with Laser cut Delrin and Chromoly reinforced side-plates
  • Launcher combines hopper with active timing belt driven floor, gate roller, and launcher wheels into one unified mechanism
  • Main flywheel is made of five 4” WCP Roller Wheels while the five hood rollers are made up of 125 2” Flex Wheels on thunderhex shaft
  • Main flywheel is driven independently from the hood rollers, each with a Falcon 500 to allow for on the fly adjustment of each velocity to influence trajectory
  • PID loop tuned to allow spin up in under 1 second
  • Entire Launcher mounted on a pin joint as a clamshell to allow access to electronics and to change batteries
Climber:
  • Single stage Mid Rung climber powered by two Falcon 500s
  • Extended via Constant Force spring and retracted by a winch
  • 3D printed spool with an integrated Cam that allows strap to be swapped rapidly while ensuring the first wrap under tension clamps down on the Cam to secure the strap from slipping
  • Climber Gearbox is mounted above the main flywheel for maximum serviceability of the spools
  • Passively deployed 4-bar High Rung climber utilizing gas shocks which are kept compressed during match play via two Delrin plates latched to the elevator
  • Once the Mid Rung climber lifts the robot fully into the air, the High Rung 4-bar passively latches past the rung and onto it
  • The weight of the robot is sufficient to back drive the elevator and release from the Mid Rung, theoretically allowing the Mid to High transition to occur after the buzzer so long as the robot is latched on both Rungs by T=0.
Climb
Autonomous:
  • Multiple options for Drive Only, Single Ball, and Two Ball Autonomous for our first event
  • Options for three, four, and more balls are under development
  • Intake on opposite side from launcher helps greatly with reducing the need to turn the robot around to complete more complex autos
Auton
The MidKnight Inventors are excited to compete at our first event of the 2022 season this weekend at the FMA District Bridgewater-Raritan Event.
This is a very innovative climb.
Looking forward to seeing your bot at Bridgewater in a few hours!!
Thats a lot of flex wheels…
Really liking this climb, nice stuff!
Drostapillar V2! :smiley:
Our of curiosity do you have photos sans bumpers? More photos in general would be nice. Zooming into these photos I’m catching hints of things that are probably very clever little details. Even those bumper attachments look interesting.
Best climb I think we have seen any team release yet. Super clean.
Definitely redeems the Drostapillar
Here is an early season picture without bumpers as well as a CAD wireframe!
Not my idea, mamas. I helped troubleshoot and redesign a small issue with the 4 bar deploy but the original design was a student’s idea. Libby & Sarath figured out how to get it to jump 2->3 upon disable.
I can’t make a clever portmanteau with their names and caterpillar though.
Seriously though, I love this climb and am so jealous I did not think of something like this. This is the best one I’ve seen yet. The jump to 3 upon disable is pure genius.
I am definitely rooting for 1923/1914 from afar again. Your latest robots have been outstanding and I’m very excited for you.
Well they killed it this year then. I’m with Akash, jealous that I didn’t think of it. Between the lobbing shot and the fast hang I expect both robots to be fierce contenders in MAR
Do you have any more info on how this works? This sounds very interesting coming from a team who struggled with consistent tension on our spool in week 1.
Sure, here is a cross-sectional view of the spool:
It consists of three 3D printed parts, the two spool halves and a cam. The cam has a round standoff pressed into it and is secured via two small shoulder bolts to the main halves of the spool allowing it to pivot. There is a .75" Hex OD, .5" Hex ID hub pressed into the two halves as well as a pair of standoffs in the smaller holes to clamp the halves together. From there simply feed your strap through the cam and adjust to your desired tension. Ideally one or two wraps under tension will be sufficient to clamp the cam down onto the strap and hold it from slipping.
Let me know if you’d like more information!
9063T33
Don’t you feel as though this is unfair to other teams? You are using your massive numbers to completely overwhelm any other team. For competing you guys were two teams with the same robot but for Chairman’s you guys were the same team.
You’re a bit late to this argument
To be fair, we were the second ones to show up at this party.
Hopefully more teams get to do what we were able to do this season. Our students were twice as engaged at home, got twice as many matches with their team(s) participating to watch, and we had twice as many opportunities to work with other teams in matches and in the pits, both to learn from them and in some cases they were able to learn things from us. All in all we are proud of the amount of participation we are able to give our students coming off a two year hands-on robotics hiatus.
In terms of fairness, we played by all the pertinent rules and regulations laid out in the game and event manual and paid 2x of all registration fees, so yes, we do think this is fair.
Are you under the impression that we submitted for Chairman’s with both teams?
Wow its almost like @anon24941552 was on 11 and 193
No way he knows how they run.
@anon24941552 @SJaladi @Libby_K feel free to not respond to this person.
I feel like saying another team is doing it so we can do it also does not truly address the problem. It should not be the standard.
Karthik and Bobby are referring to the arguments that already take place in those respective threads.
Your alt, assuming you’re already a forum member, isn’t helping btw.
