Teleop Code Not Running
We’re currently trying to write some simple teleop code for our robot to move:
However the code will not run (robot won’t move), and neither eclipse or the driver station is giving us errors of any sort. Robot code, joysticks, and communication are all green in the driver station. How do we fix this?
I do not think you can allocate the same resource to two objects, i.e. UI joystick 0 is being allocated to both the left and right Joystick objects.
This is correct. I’m actually surprised the code isn’t crashing due to this. Perhaps it’s because it’s an OI resource instead of a RoboRIO port.
