Telescoping arm vs. linear gears
what are the pros and cons of each solution?
What is the problem you are facing? What are your manufacturing capabilities?
Let’s start with: You’re asking about two items that are not mutually exclusive. A “linear gear” can be used to extend and retract a telescoping arm. (Also, there are at least two options for “linear gear”–rack-and-pinion, and leadscrew/linear actuator.)
