I’ve been working on developing a telescoping system for my teams robot. I planned on using some t-slot aluminum (80/20?), does anyone have designs they wouldn’t mind sharing or idea on how to develop one? I’ve searched around without much luck.
Also where is a good place to buy some T-slot tubing?
Our 2007 robot used a 2-stage (more like 1.5 stage) 80/20 telescoping elevator using the 80/20 linear glide pieces. Here’s a link to all our photos from the 2007 season:
You can look on the 80/20 website to find distributors near you. The local distributors are usually very helpful and usually give a 10% discount to FIRST teams.
artdutra: thats the approach i was going for, it was just how the slider worked and how i would use pulleys to make it slide up and down
the taller you make something the more top heavy it will become. think of it like a cheater bar. the longer you make something the easier it is to say move/turn it. so the taller you make the bot the easier it becomes for it to tip over
Check out this white paper from Andy Baker (of AndyMark):
It explains more about various mechanism types (including elevator) and shows the two styles of elevator (continuous versus cascade). Our 2007 robot used the cascade approach.
