Hello Terragen users. I’m having trouble creating a terrain for my landscapes, anybody have any pointers?
I could use some help too.
where do i even get the program. it sounds cool and i would like to use it
Here you go - http://www.planetside.co.uk/terragen/
It’s cool, just takes a little time to figure out.
thanks
You could start off by going to “generate terrain” then modify one…once you figure out that you should be able to figure out the other stuff…
Here are some of the ones i’ve done…
http://files.joako.com/new-cg-terrain4-small2.PNG
Here are some more…
If you guys need specific help IM me at “twinattack”, i’m on quite a bit…
it’s funny how I found the program, and yet my computer is the only one that crashes while running it.
/me goes back to building roller coasters.
Here are some tutorials that are pretty straight forward…although some of the stuff might be worded different because of an older version…
Hey clark,
I’m having trouble getting the rendered images at a good quality, everything is very pixily, idk why that is but it is weird,
let me know if you have any sugestions to making the quality better
tyler
Do you see the “Render Preview” button on the “Rendering Control” window?..if so all you have to do is adjust the “Detail” slider all the way up…
That’s the only way that i know of so far…
yeha i did, strange, oh well ill screw around with it some more
after getting the kinks out, here is one thta i just made…
