tether after a match
Posted by joe frick at 03/11/2001 10:35 PM EST
Engineer on team #466, bartram braves, from john bartram high school and sheet metal workers local union 19.
does anyone know if it is legal to hook up a tether after the end of the match to collapse a robot, i would be using a seperate control system(last years), to collapse our robot in order to remove it from the field without hassle if we should end the match in the uprite position. thank you
Posted by Chris Hardman at 03/11/2001 10:39 PM EST
Student on team #111, WILDSTANG, from Rolling Meadows and Wheeling High schools and motorola.
In Reply to: tether after a match
Posted by joe frick on 03/11/2001 10:35 PM EST:
: does anyone know if it is legal to hook up a tether after the end of the match to collapse a robot, i would be using a seperate control system(last years), to collapse our robot in order to remove it from the field without hassle if we should end the match in the uprite position. thank you
yes- as long as your robot is off the field, we had to do this a couple of times to reset our robot for the finals mathces and when we had matches right after each other.
chris hardman
Posted by joe frick at 03/11/2001 10:44 PM EST
In Reply to: Re: tether after a match
Posted by Chris Hardman on 03/11/2001 10:39 PM EST:
: : does anyone know if it is legal to hook up a tether after the end of the match to collapse a robot, i would be using a seperate control system(last years), to collapse our robot in order to remove it from the field without hassle if we should end the match in the uprite position. thank you
: yes- as long as your robot is off the field, we had to do this a couple of times to reset our robot for the finals mathces and when we had matches right after each other.
: chris hardman
so we would have to carry it off the field ,say just over the rail then hook up, even if its 10 feet tall at the time we shut down
Posted by Chris Hardman at 03/11/2001 10:50 PM EST
Posted by joe frick on 03/11/2001 10:44 PM EST:
: : : does anyone know if it is legal to hook up a tether after the end of the match to collapse a robot, i would be using a seperate control system(last years), to collapse our robot in order to remove it from the field without hassle if we should end the match in the uprite position. thank you
: : yes- as long as your robot is off the field, we had to do this a couple of times to reset our robot for the finals mathces and when we had matches right after each other.
: : chris hardman
: so we would have to carry it off the field ,say just over the rail then hook up, even if its 10 feet tall at the time we shut down
yes, like the other posts say, you need to alter your robot so you wont have this problem ours is 4 ft wide and possibly 6 ft long at the end of the match
Posted by Scott Strickland at 03/11/2001 10:42 PM EST
Engineer on team #21, ComBBAT, from Astronaut & Titusville High School and Boeing/NASA.
Rules say your robot must be able to get off the field without having to be powered up.
We required a tether after one match in order to get our hook to let go of the goal. Refs told us to fix it before the next match, or not play again. Our hook is powered by the seat track motor. Since then we take a cordless drill to open up the hook (on the flex shaft). Ref’s have no problem with that.
If your using the tether outside of the playing field, there should be no problem.
Scott
Team 21
Posted by Michael Martus at 03/11/2001 10:43 PM EST
Coach on team #47, Chief Delphi, from Pontiac Central H.S. and Delphi Automotives Systems.
I was a field attendant at the Western Michigan Regional and have the answer for you.
There is no powering up of any robot after the match is over. This includes using your tether or other powering device to move your robot. Consult the main rules for the FIRST competition, they are very specific on this matter. There are no exceptions.
There is a target time of 2.5 min. after a match is over for clearing the field and the setup for the next match. Having robots not able to let go of things is a real problem.
You will need to alter your robot.
I was also a robot inspector and we checked for just such a problem.
Posted by Anton Abaya at 03/11/2001 10:59 PM EST
Coach on team #419, Rambots, from UMass Boston / BC High and If only we had free donuts…
Posted by Michael Martus on 03/11/2001 10:43 PM EST:
…without being noticed.
it’s a nono, but some teams still do it. fyi.
:slight_smile: anton
Posted by colleen - T190 at 03/12/2001 12:04 AM EST
Engineer on team #190, Gompei, from Massachusetts Academy of Math and Science and WPI.
Had we not been able to tether the robot up on the sidelines in UTC (basically… lifted off the field and onto cart as is… moved into waiting area…) we wouldn’t have been able to fit it through the door to get it back into the pit in about 50% of our matches (last move was dropping a ball… we’re extended 8ft in the air)…
So you can’t tether ON the field… but you can tether once you’re out of the way… (it’s safer… and well, some teams can’t get back to the pit otherwise)… am i correct?
Posted by Jessica Boucher at 03/12/2001 6:02 PM EST
Student on team #237, Sie-H2O-Bots, from Watertown High School and Eastern Awning Systems & The Siemon Company.
In Reply to: No tethering ON the field-- right?
Posted by colleen - T190 on 03/12/2001 12:04 AM EST:
: So you can’t tether ON the field… but you can tether once you’re out of the way… (it’s safer… and well, some teams can’t get back to the pit otherwise)… am i correct?
You know how long we were when we were fully extended at UTC :wink: We had to do the same.
-Jessica B, #237
