I found this in team update number 13
where it talks about the Targ0000.tga
I thought it was just to render things faster but the other peoples ib the team think that we have to keep it with tga…
What do we do???
What do we do???
*Originally posted by LizJJury *
**I found this in team update number 13where it talks about the Targ0000.tga
What do we do??? **
Ok, what autodesk is saying as a tip is actually what already happens automatically when you network render or just render multiple frames at a time.
Basically the tip means… Save your files as this filename0000.type of format (the 0000 should be your frame number that you are starting out on (remember you start on frame 0 not 1)) So for instance when I go to render my 909 files at 30.03 fps I save it as Team93animation0000.jpg the program will automatically rename the files in chronological order like Team93animation0001.jpg Team93animation0002.jpg ect…
The file format does not matter but different compressions take different amount of time to render and take up different amount of space.
If you need more clarification on this pm me.
