The blank final field constants may not have been initialized Java(33554513) Error
Simulation code Error
DifferentialDrivetrainSim m_driveSim = new DifferentialDrivetrainSim(
DCMotor.getNEO(2),       // 2 NEO motors on each side of the drivetrain.
7.29,                    // 7.29:1 gearing reduction.
7.5,                     // MOI of 7.5 kg m^2 (from CAD model).
60.0,                    // The mass of the robot is 60 kg.
Units.inchesToMeters(3), // The robot uses 3" radius wheels.
0.7112,                  // The track width is 0.7112 meters.
// The standard deviations for measurement noise:
// x and y:          0.001 m
// heading:          0.001 rad
// l and r velocity: 0.1   m/s
// l and r position: 0.005 m
VecBuilder.fill(0.001, 0.001, 0.001, 0.1, 0.1, 0.005, 0.005));
public DriveSim() {
m_leftEncoder.setDistancePerPulse(2 * Math.PI * 6.35 / 40158);
m_rightEncoder.setDistancePerPulse(2 * Math.PI * 6.35 / 40158);
SmartDashboard.putData("Field", m_field);
// I’ve tried to do a robot simulation but that function just gave that error. Although it is illogical, I putted a bracket under that code" VecBuilder.fill(0.001, 0.001, 0.001, 0.1, 0.1, 0.005, 0.005));" it seems it’s solved but another error showed again
Can you provide the full error output, and preferably a link to your code (i.e. in github)?
In short, that error means you have a variable somewhere defined as “final” but without a value, nor does it get a value assigned in the constructor.
