Well I was checking my team’s (201) win loss record on TBA, and for some reason I noticed that there was a Semi 0 Match 0 and it was the exact same match as Semi 2 Match 3. I then looked here to find that there was the same situation in the quarterfinals and the finals. What is stranger is that the Match 0 always occurred during the 3rd match (in each final level) that the alliance 2188 904 1918 played in.
I wonder if this happened in any other regional records?
You’d probably be better off having a moderator move this to the The Blue Alliance Folder of this forum, you’ll be more likely to get a reply from one of the guys that handles TBA.
I wasn’t sure where I would get the best response from them, but I will be sure to have a moderator move it as soon as possible!
Yeah, it’s ok, that folder is kinda hidden down at the bottom there so most people don’t see it I think. :rolleyes:
It appears FIRST is putting up bad match result data sometimes. I will have to add a safeguard to prevent scraping that. I’ve seen a few Qual 0’s as well…
Thanks!
