Does anyone knows a quick and easy way to bumpers on
Bolt and wing nut, maybe?
If you intend to follow the rules, then there is only one way, bolts.
Please read the rules for bumped design specifications.
<R08> “…STANDARD BUMPERS must be constructed as described below… STANDARD BUMPERS must be
attached to the ROBOT with a boltand-
fastener system to form a
rigid, robust connection to the
ROBOT structure…”
We used bolts with lock nuts so they won’t come off during competition.
Do you have problems fitting into the box for inspection?
I would use bolts, assuming your pit will have a wrench.
Good luck:)
What if they are magic bolts?
Uhm, didn’t the post state that they’re using bolts? With lock nuts. Or maybe I’m missing something here…
