How can I use the CTRE’s phoenix5
package to run VictorSPX? I used to instantiate phoenix5.WPI_VictorSPX()
but in my last RobotPy update it displays for me that the package does not exist.
Any tips to solve this issue?
Are you implementing “ctre
” in your robotpy_extras
? If so, I believe Phoenix 5 and 6 are separate libraries now, try “phoenix5
ctre
was my second try, but I have already tested with phoenix5
on robotpy_extras
, and it did not work.
Weird. You could try implementing it in your required
libraries to see if that works, we’ve done that for phoenix 6 before the stable releases came out this year.
Add robotpy-ctre to requires.
Seems to need more than the requires. We’ve added that, and it appears to download to the local PC on robotpy sync
, but the robot code fails on import in the same way as the OP.
For us, it is phoenix6 and rev both. Both are in robotpy_extras, and the corresponding robotpy-ctre and robotpy-rev are in requires.
Why did it change? Will something happen with phoenix5
so that it won’t be placed in robotpy_extras
My goal is for robotpy_extras to go away next year. The way it’s implemented means somethings it ends up with issues like this, and requires should always Just Work.
