The Program Compiles and Deploys, but the sidecar doesn't connect
Okey, today our team tried to test out our new robot setup with the new code. We tried at least 5 times with different codes, which all compile and deploy successfully. However, the sidecar continues to blink slow and the compressor doesn’t run. Please help, and respond.
Team 810 Bulls
If you look at the errors coming from WPI, that will likely indicate that code and cRIO FPGA aren’t the same version. The solution if that is the problem, is to reimage the cRIO to the most recent version. Be sure to check the checkbox to reformat.
Greg McKaskle
